How to create 8 bits to a variable
I'm reading an output signal consiting of 3 (L,M,H) bytes (3x 8 bits) from a sensor.
This output signal however does not always need to be represented by 8 bits.
ex 010101 = 00010101
I would like to force the variable to consist of 8 bits no matter the size of the input number. All input bytes should be represented with an 8-bit length.
This is what my code looks like:
byte L = 00000000;
byte M = 00000000;
byte H = 00000000;
while (Serial.available()) {
byte L = Serial.read();
byte M = Serial.read();
byte H = Serial.read();
Serial.println(L, BIN);
Serial.println(M, BIN);
Serial.println(H, BIN);
Taking this as an example, the variable L will always be 8 bits in length.
Serial.print() does not print leading zeros, hence the variable appears to be only 6 bits in length.
btw, the bytes L, M and H that you have in setup() are different to the bytes L, M and H that you have in loop() - so you are not using the ones in setup().
This is flawed.
You've hit problem #1 in my list!
