I made a program on the ESP8266 with the addition of RTC, DHT22, lcd i2c 16x2 and SDcard. then to show the time on the power lcd use RTC hours and minutes. for the seconds pointer I want to symbolize it as a colon ":" which flashes every second. at first I managed to make the program but then when I added another function to send data to firebase. the colon that should be ticking actually freezes. any suggestions what i should do?
#include "SPI.h"
#include "SD.h"
#include "DHT.h"
#include "RTClib.h"
#include <Wire.h>
#include "PCF8574.h"
#include <ESP8266WiFi.h>
#include <Firebase_ESP_Client.h>
#define DHTPIN D4
#define DHTTYPE DHT22
/*Default Trigger Setting*/
int tTrigger = 0;
int hTrigger = 0;
LiquidCrystal_I2C lcd(0x27, 16, 2);
RTC_DS1307 rtc;
DHT dht(DHTPIN, DHTTYPE);
File dataFile;
PCF8574 io(0x20);
#include "addons/TokenHelper.h"
#include "addons/RTDBHelper.h"
#define WIFI_SSID
#define WIFI_PASSWORD
#define API_KEY
#define USER_EMAIL
#define USER_PASSWORD
#define STORAGE_BUCKET_ID
#define DATABASE_URL
FirebaseData fbdo;
FirebaseAuth auth;
FirebaseConfig config;
const int chipSelect = D8;
int rkipas = 0;
int rpump = 1;
const unsigned long intervalSdcard = 5000;
unsigned long timeSdcard = 0;
const unsigned long intervalStorage = 360000;
unsigned long timeStorage = 0;
const unsigned long intervalRTDB = 1000;
unsigned long timeRTDB = 0;
unsigned long getDataPrevMillis = 0;
unsigned long getDataDisplayPrevMillis = 0;
unsigned long sendIntPrevMillis = 0;
int P1=2;
int P2=3;
int P3=4;
int hourupg;
int minupg;
int yearupg;
int monthupg;
int dayupg;
int menu =0;
char FileName[] = "000000.txt";
while (!Serial) {}
delay(3000); // wait for console opening
if (! rtc.begin()) {
Serial.println("Couldn't find RTC");
while (1);
if (!rtc.isrunning()) {
Serial.println("RTC lost power, lets set the time!");
rtc.adjust(DateTime(__DATE__, __TIME__));
if (!SD.begin(chipSelect)) {
Serial.println("Initialization failed!");
while (1);
io.begin();
dht.begin();
lcd.init();
lcd.backlight();
int menu=0;
WiFi.begin(WIFI_SSID, WIFI_PASSWORD);
for(int i=0; i <= 100; i++)
lcd.setCursor(0,0);
lcd.print("connecting wifi!");
lcd.print(" ");
updateProgressBar(i, 100, 1);
delay(100);
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Connected IP: ");
lcd.setCursor(0,1);
lcd.print(WiFi.localIP());
delay(3000);
lcd.clear();
Serial.printf("Firebase Client v%s\n\n", FIREBASE_CLIENT_VERSION);
config.api_key = API_KEY;
auth.user.email = USER_EMAIL;
auth.user.password = USER_PASSWORD;
config.token_status_callback = tokenStatusCallback;
config.database_url = DATABASE_URL;
lcd.setCursor(0,0);
lcd.print("Connected to");
lcd.setCursor(0,0);
lcd.print("Firebase Client");
lcd.clear();
Firebase.begin(&config, &auth);
Firebase.reconnectWiFi(true);
Serial.printf("Set int... %s\n", Firebase.RTDB.setInt(&fbdo, "/SetVal/SetTemp", 27) ? "ok" : fbdo.errorReason().c_str());
Serial.printf("Set int... %s\n", Firebase.RTDB.setInt(&fbdo, "/SetVal/SetHumi", 85) ? "ok" : fbdo.errorReason().c_str());
#if defined(ESP8266)
fbdo.setBSSLBufferSize(1024, 1024);
#endif
fbdo.setResponseSize(1024);
int h = dht.readHumidity();
int t = dht.readTemperature();
if (isnan(h) || isnan(t)) {
Serial.println("Failed to read from DHT sensor!");
return;
if(io.read(P1))
menu=menu+1;
if (menu==0)
DisplayDateTime();
SavingData();
if (menu==1)
DisplaySetHour();
if (menu==2)
DisplaySetMinute();
if (menu==3)
DisplaySetYear();
if (menu==4)
DisplaySetMonth();
if (menu==5)
DisplaySetDay();
if (menu==6)
StoreAgg();
menu=0;
delay(100);
void updateProgressBar(unsigned long count, unsigned long totalCount, int lineToPrintOn)
double factor = totalCount/80.0;
int percent = (count+1)/factor;
int number = percent/5;
int remainder = percent%5;
if(number > 0)
lcd.setCursor(number-1,lineToPrintOn);
lcd.write(5);
lcd.setCursor(number,lineToPrintOn);
lcd.write(remainder);
void SavingData(){
lcd.setCursor (0,0);
lcd.print("sensor failed!");
return;
DateTime now = rtc.now();
FileName[0] = now.day()/10 + '0';
FileName[1] = now.day()%10 + '0';
dayupg=now.day();
FileName[2] = now.month()/10 + '0';
FileName[3] = now.month()%10 + '0';
monthupg=now.month();
FileName[4] = (now.year()/10)%10 + '0';
FileName[5] = now.year()%10 + '0';
yearupg=now.year();
FileName[10] = '\0';
String fileNameStr = "/";
fileNameStr += FileName;
String dataString = "";
if (now.day()<=9)
dataString += "0";
dataString += String(now.day(), DEC);
dayupg=now.day();
dataString += "/";
if (now.month()<=9)
dataString += "0";
dataString += String(now.month(), DEC);
dataString += "/";
dataString += String(now.year() - 2000);
yearupg=now.year();
dataString += " | ";
if (now.hour()<=9)
dataString += "0";
dataString += String(now.hour(), DEC);
hourupg=now.hour();
dataString += ":";
if (now.minute()<=9)
dataString += "0";
dataString += String(now.minute(), DEC);
minupg=now.minute();
dataString += String(h);
dataString += String("%");
dataString += String(t);
dataString += String("°C");
unsigned long currentTime = millis();
if ( currentTime - timeSdcard >= intervalSdcard) {
dataFile = SD.open(FileName, FILE_WRITE);
if (dataFile) {
dataFile.println(dataString);
dataFile.close();
Serial.println(dataString);
else {
Serial.print("error opening : ");
Serial.println(FileName);
timeSdcard = currentTime;
if (Firebase.ready() && currentTime - timeStorage >= intervalStorage)
Serial.print("Upload file : ");
if (Firebase.Storage.upload(&fbdo, STORAGE_BUCKET_ID, fileNameStr.c_str(), mem_storage_type_sd, FileName, "data.txt"))
Serial.printf("\nDownload Link: %s\n", fbdo.downloadURL().c_str());
Serial.println(fbdo.errorReason());
timeStorage = currentTime;
Serial.printf("Suhu send to RTDB... %s\n", Firebase.RTDB.setInt (&fbdo, "/Hasil_Pembacaan/suhu", t) ? "ok" : fbdo.errorReason().c_str());
Serial.printf("Kelembaban send to RTDB.... %s\n", Firebase.RTDB.setInt(&fbdo, "/Hasil_Pembacaan/kelembaban", h) ? "ok" : fbdo.errorReason().c_str());
Serial.printf("tTrigger Control... %s\n", Firebase.RTDB.getInt(&fbdo, "/SetVal/SetTemp") ? String(fbdo.intData()).c_str() : fbdo.errorReason().c_str());
tTrigger = fbdo.intData();
if ( t >= tTrigger){
io.write (rkipas, LOW);
lcd.setCursor(10, 0);
lcd.print(">");
else {
io.write (rkipas, HIGH);
lcd.print(" ");
Serial.printf("tTrigger Control... %s\n", Firebase.RTDB.getInt(&fbdo, "/SetVal/SetHumi") ? String(fbdo.intData()).c_str() : fbdo.errorReason().c_str());
hTrigger = fbdo.intData();
if ( h <= hTrigger){
io.write (rpump, LOW);
lcd.setCursor(10, 1);
lcd.print(">");
else {
io.write (rpump, HIGH);
lcd.print(" ");
void DisplayDateTime ()
return;
lcd.setCursor(11, 0);
lcd.print(" ");
lcd.print(t);
lcd.print(char(223));
lcd.print("C");
lcd.setCursor(11, 1);
lcd.print(" ");
lcd.print(h);
lcd.print("% ");
lcd.setCursor(0, 0);
if (now.hour()<=9)
lcd.print("0");
lcd.print(now.hour(), DEC);
hourupg=now.hour();
lcd.setCursor(3, 0);
lcd.print("0");
lcd.print(now.minute(), DEC);
int detik = now.second();
if (detik % 2 == 0)
lcd.setCursor(2, 0);
lcd.print(":");
lcd.print(" ");
lcd.setCursor(0, 1);
if (now.day()<=9){
lcd.print("0");
lcd.print(now.day(), DEC);
dayupg=now.day();
lcd.print("/");
if (now.month()<=9){
lcd.print("0");
lcd.print(now.month(), DEC);
lcd.print("/");
lcd.print((now.year()-2000), DEC);
yearupg=now.year();
void DisplaySetHour()
lcd.clear();
if(io.read(P2)==HIGH){
if(hourupg==23)
hourupg=0;
hourupg=hourupg+1;
if(io.read(P3)==HIGH){
if(hourupg==0)
hourupg=23;
hourupg=hourupg-1;
lcd.setCursor(0,0);
lcd.print("Set time:");
lcd.setCursor(0,1);
lcd.print(hourupg,DEC);
delay(200);
void DisplaySetMinute()
lcd.clear();
if (minupg==59)
minupg=0;
minupg=minupg+1;
if (minupg==0)
minupg=59;
minupg=minupg-1;
lcd.setCursor(0,0);
lcd.print("Set Minutes:");
lcd.setCursor(0,1);
lcd.print(minupg,DEC);
delay(200);
void DisplaySetYear()
lcd.clear();
yearupg=yearupg+1;
yearupg=yearupg-1;
lcd.setCursor(0,0);
lcd.print("Set Year:");
lcd.setCursor(0,1);
lcd.print(yearupg,DEC);
delay(200);
void DisplaySetMonth()
lcd.clear();
if (monthupg==12)
monthupg=1;
else{monthupg=monthupg+1;
if (monthupg==1)
monthupg=12;
else{monthupg=monthupg-1;
lcd.setCursor(0,0);
lcd.print("Set Month:");
lcd.setCursor(0,1);
lcd.print(monthupg,DEC);
delay(200);
void DisplaySetDay()
lcd.clear();
if (dayupg==31)
dayupg=1;
dayupg=dayupg+1;
if (dayupg==1)
dayupg=31;
else{dayupg=dayupg-1;
lcd.setCursor(0,0);
lcd.print("Set Day:");
lcd.setCursor(0,1);
lcd.print(dayupg,DEC);
delay(200);
void StoreAgg()
lcd.clear();
lcd.setCursor(0,0);
lcd.print("SAVING IN");
lcd.setCursor(0,1);
lcd.print("PROGRESS");
rtc.adjust(DateTime(yearupg,monthupg,dayupg,hourupg,minupg,0));
lcd.clear();
delay(200);
}ketik atau tempel kode di sini
