Hello,
I'm trying to display a custom error when compiling my code if col and greater than x.
Function prototype:
void Coffee :: print42 (int col)
Hello,
Function prototype:
Google for: c++ preprocessor error message
Not sure, is this what you wanted ?
#define col 10
#define test 5
#if col > test
#error col must be less than test
#endif
I don't think you cant do that in your case.
you have a member function (print42()
) and it takes a parameter. The compiler has no clue what value will be passed at run time and the parameter could be the outcome of a runtime calculation say myCoffeeInstance.print32(analogRead(A0));
. ➜ there is no way thus the compiler could figure this out.
if this class is in a library, it could be even compiled without anyone calling the function and only the linker will bring that code in when you develop a project
➜ you need to handle that at runtime and fail in a managed way that won't crash the code
I told myself that what I wanted was not possible, but I prefer to ask.
Thank you for your answers.
Is there a way to close a subject, or do you have to wait 4 months?
#include <stdio.h>
int main(void)
printf("I ❤️ Arduino");
return(0)
Before coming I had already searched without finding what I want but thank you anyway
I marked your answer as the solution, that will soft close the topic
