How to create an audio switch?
Hi All, My requirement is, to create an Audio Switch. The switch will have various Audio inputs(3.5mm/Stereo cable), and one Output(3.5mm). When I request for one of the Audio sources(which are inputs), I should get only that Audio source. Is it possible to create something like this via Arduino Uno? Please let me know where I need to start and what all the components I would need? I am new to Ardiuno with very less Electronics knowledge(But I do have programmatical knowledge), so please help me where I need to start and which modules I need to have look at. Any help is greatly appreciated.
Have a look at:
http://forum.arduino.cc/index.php?topic=206810.msg1742774#msg1742774
If its stereo audio, use a 4052.
But you have to bias the input or output at 2.5v with a couple of resistors because otherwise the signal can't swing negative and will clip.
And AC-couple the inputs and outputs with capacitors.
See:
