How to create and edit a time variable for a pushbutton alarm clock with DS3231
I have a school project to make an alarm clock. The tutorial given uses the code below. I don’t understand how to create a variable for year, month, day, hour and minute. Then I need to add or subtract one from that variable to select the correct time. Thanks for your help,
I2Cds3232.ino (3.03 KB)
// DS3232 I2C test
#include "Wire.h"
#define DS3232_I2C_ADDRESS 0x68
// Convert normal decimal numbers to binary coded decimal
byte decToBcd(byte val)
  return ( (val/10*16) + (val%10) );
// Convert binary coded decimal to normal decimal numbers
byte bcdToDec(byte val)
  return ( (val/16*10) + (val%16) );
  Wire.begin();
void readDS3232time(byte *second,
byte *minute,
byte *hour,
byte *dayOfWeek,
byte *dayOfMonth,
byte *month,
byte *year)
  Wire.beginTransmission(DS3232_I2C_ADDRESS);
  Wire.write(0); // set DS3232 register pointer to 00h
  Wire.endTransmission();
  Wire.requestFrom(DS3232_I2C_ADDRESS, 7); // request 7 bytes of data from DS3232 starting from register 00h
  // A few of these need masks because certain bits are control bits
  *second     = bcdToDec(Wire.read() & 0x7f);
  *minute     = bcdToDec(Wire.read());
  *hour       = bcdToDec(Wire.read() & 0x3f);  // Need to change this if 12 hour am/pm
  *dayOfWeek  = bcdToDec(Wire.read());
  *dayOfMonth = bcdToDec(Wire.read());
  *month      = bcdToDec(Wire.read());
  *year       = bcdToDec(Wire.read());
void setDS3232time(byte second, byte minute, byte hour, byte dayOfWeek, byte dayOfMonth, byte month, byte year)
// sets time and date data to DS3232
  Wire.write(0); // sends 00h - seconds register
  Wire.write(decToBcd(second));     // set seconds
  Wire.write(decToBcd(minute));     // set minutes
  Wire.write(decToBcd(hour));       // set hours
  Wire.write(decToBcd(dayOfWeek));  // set day of week (1=Sunday, 7=Saturday)
  Wire.write(decToBcd(dayOfMonth)); // set date (1~31)
  Wire.write(decToBcd(month));      // set month
  Wire.write(decToBcd(year));       // set year (0~99)
void displayTime()
  byte second, minute, hour, dayOfWeek, dayOfMonth, month, year;
  // retrieve data from DS3232
  readDS3232time(&second, &minute, &hour, &dayOfWeek, &dayOfMonth, &month, &year);
  // send it to the serial monitor
  Serial.print(hour, DEC);// convert the byte variable to a decimal number when being displayed
  Serial.print(":");
  if (minute<10)
      Serial.print("0");
  Serial.print(minute, DEC);
  Serial.print(":");
  if (second<10)
      Serial.print("0");
  Serial.print(second, DEC);
  Serial.print("  ");
  Serial.print(dayOfMonth, DEC);
  Serial.print("/");
  Serial.print(month, DEC);
  Serial.print("/");
  Serial.print(year, DEC);
  Serial.print("  Day of week:");
  switch(dayOfWeek){
  case 1:
    Serial.println("Sunday");
  case 2:
    Serial.println("Monday");
  case 3:
    Serial.println("Tuesday");
  case 4:
    Serial.println("Wednesday");
  case 5:
    Serial.println("Thursday");
  case 6:
    Serial.println("Friday");
  case 7:
    Serial.println("Saturday");
   // setDS3232time(00, 31, 23, 2, 23, 7, 12);   // set DS3232 seconds, minutes, hours, day of week, date, month, year
   displayTime();
Thanks for the quick reply. I should have explained better like if button== HIGH have the hours increment by 1 or ++. Thanks
