How to Create Array of Objects?
This seems very easy, but I can’t figure it out. I’d like to create 3 objects, and keep their references in an array. My plan is to use 3 OneWire buses, so it would obviously help to keep their Object references in an array.
I originally thought something like this would work
OneWire buses[3];
for(i = 0; i < 3; i++) {
  // Create 1W objects on pins 8,9,10
  buses[i] = new OneWire(i + 8);
…but this doesn’t seem to work. After some searching I found syntax like this:
int[] myArray = new int[3];
…although I can’t get this to work (at least with arduino-0017), and don’t see how I’d instantiate the objects with different parameters.
I’m a bit lost - can anyone help me? Thanks!
That looks like Java. C++ equivalent is int myArray[3];
OneWire buses[3];
I see no problem with this, what was the error you got?
I guess I should have posted my code etc. earlier…? :wink:
Okay, here’s my code:
#include <OneWire.h>
OneWire buses[3];
…which has a compile error:
error: no matching function for call to 'OneWire::OneWire()'
/arduino-0017/hardware/libraries/OneWire/OneWire.h:43:
note: candidates are: OneWire::OneWire(uint8_t)
I can’t seem to find a way to declare the reference without actually creating the object, and then can’t instantiate three objects with different arguments.
Any ideas?
//I have not checked to see if pins 2,3,4 is usable with this library.
OneWire buses[3] = {
  OneWire(2),
  OneWire(3),
  OneWire(4)
Perfect - that works nicely. I'm up and running now - thank you!
Just out of interest, is there a way to declare an object reference without instantiating it (either singularly, or in an array)?
I thought that was the advantage of using references over using pointers - you can’t have an uninitialised reference, so you have to have an instance of the object.
You should be able to create a pointer to an object as follows:
OneWire *ptrOneWire;
Creating one however doesn't make sense until you make it point to an instance.
You can also write a function that take an object reference as a parameter:
void ReadOne(OneWire &ow)
  // access any OneWire instance passed as parameter
  ow.
