how to create / buy a servo horn for 28BYJ-48 engine ?
anyone can suggest how to create / buy some servo horn for 28BYJ-48 engine to connect items to it ?
I've tried to sandwitch the engine pin with 2 metal bars with bolts but its still not stable .
thanks,
Fabio
What is the diameter of the shaft?
I have successfully used the brass inserts from large chocolate-block connectors for connections on some motor shafts.
...R
Do you mean THESE MOTORS?
I would really like to find attachments for these!
  • Servo horn
  • And especially Wheels to make small robots...
Anyone seen these?? Thanks!
And what are these??
The shaft on my version of the 28BJY motor is 5 mm in diameter, which is standard.
You need two setscrews, one on each side of a 5 mm bore gear to engage the flats.
thanks everyone for your feedbacks !
Robin2 : the chocolate-block connectors .. really cool . I'll try.. https://goo.gl/images/OSvuJI
terryking228 : yes , this motor .
jremington : im not sure i got your idea .. can u detail little bit ?
thanks,
Fabio
Below is a picture of a pinion gear with a single set screw.
Imagine a second set screw on the opposite side of the shaft.
Instead of a servo horn or arm, consider using a hub, like this one (you would need a 5 mm bore).
jremington this is perfect, thanks :slight_smile:
And of course there is thingiverse...
