How to create library to get String value?
I want to create my library but I cannot use String in library. This is my code.
Iot.h
#ifdef Iot_h
#define Iot_h
#include "Arduino.h"
Class Iot
	public:
		Iot() {}
		int timeplus(String time);
		String getValueFromString(String data, char separator, int index)
#endif
Iot.cpp
#include "Iot.h"
  int found = 0;
  int strIndex[] = {0, -1};
  int maxIndex = data.length()-1;
  for(int i=0; i<=maxIndex && found<=index; i++){
    if(data.charAt(i)==separator || i==maxIndex){
        found++;
        strIndex[0] = strIndex[1]+1;
        strIndex[1] = (i == maxIndex) ? i+1 : i;
  return found>index ? data.substring(strIndex[0], strIndex[1]) : "";
int Iot::timeplus(String time){
      String h_str = getValueFromString(time, ':', 0);
      String m_str = getValueFromString(time, ':', 1);
      int h = h_str.toInt();
      int m = m_str.toInt();
	  int t = 0;
	  t = h + m;
	  return t;
It show error like this.
C:\Users\PC\Documents\Arduino\libraries\Iot\Iot.cpp:33:1: error: 'String' does not name a type
   33 | String getValueFromString(String data, char separator, int index)
C:\Users\PC\Documents\Arduino\libraries\Iot\Iot.cpp:51:5: error: 'Iot' has not been declared
   51 | int Iot::timeplus(String time){
C:\Users\PC\Documents\Arduino\libraries\Iot\Iot.cpp:51:23: error: 'String' was not declared in this scope
I change String to char* then it show error like this.
C:\Users\PC\Documents\Arduino\libraries\Iot\Iot.cpp:57:18: error: request for member 'toInt' in 'h_str', which is of non-class type 'char*'
   57 |    int h = h_str.toInt();
C:\Users\PC\Documents\Arduino\libraries\Iot\Iot.cpp:58:21: error: request for member 'toInt' in 'm_str', which is of non-class type 'char*'
   58 |       int m = m_str.toInt();
C:\Users\PC\Documents\Arduino\libraries\Iot\Iot.cpp: At global scope:
C:\Users\PC\Documents\Arduino\libraries\Iot\Iot.cpp:66:5: error: 'Iot' has not been declared
   66 | int Iot::timeplus(int h, int m){
How to fix it?
should it be?
#ifndef Iot_h
if you failed to include Arduino.h String would not be defined
Thank you. It works
