How to create Matter smart lock with IO
I am trying to build a Matter smart lock that has sensors for open and close positions. This seems like a very basic task, yet I've spent hours and haven't found anything helpful to make progress. I started with matter_door_lock.ino example from Silicon Labs, added it to Apple Home, and can toggle the lock COMMAND between lock and unlock. However, I can't find any commands to set the lock STATE between locked/unlocked/jammed.
I dug into the DeviceDoorLock.h and found SetLockState method, but I don't know how to initial this as the MatterDoorLock has a begin() command and the DeviceDoorLock does not. Help is greatly appreciated!
   Matter door lock example
   The example demonstrates how to create a door lock device with the Arduino Matter API.
   The sketch creates a Matter door lock device and lets users locally or remotely control it.
   The built-in LED is turned on when the lock is in the locked state.
   The device has to be commissioned to a Matter hub first.
   Compatible boards:
   - Arduino Nano Matter
   - SparkFun Thing Plus MGM240P
   - xG24 Explorer Kit
   - xG24 Dev Kit
   - Seeed Studio XIAO MG24 (Sense)
   Author: Tamas Jozsi (Silicon Labs)
#include <Matter.h>
#include <MatterDoorLock.h>
#ifndef BTN_BUILTIN
#define BTN_BUILTIN PA0
#endif
MatterDoorLock matter_door_lock;
void handle_button_press();
volatile bool button_pressed = false;
  Matter.begin();
  matter_door_lock.begin();
  pinMode(BTN_BUILTIN, INPUT_PULLUP);
  attachInterrupt(BTN_BUILTIN, &handle_button_press, FALLING);
  pinMode(LED_BUILTIN, OUTPUT);
  digitalWrite(LED_BUILTIN, LED_BUILTIN_INACTIVE);
  Serial.println("Matter door lock");
  if (!Matter.isDeviceCommissioned()) {
    Serial.println("Matter device is not commissioned");
    Serial.println("Commission it to your Matter hub with the manual pairing code or QR code");
    Serial.printf("Manual pairing code: %s\n", Matter.getManualPairingCode().c_str());
    Serial.printf("QR code URL: %s\n", Matter.getOnboardingQRCodeUrl().c_str());
  while (!Matter.isDeviceCommissioned()) {
    delay(200);
  Serial.println("Waiting for Thread network...");
  while (!Matter.isDeviceThreadConnected()) {
    delay(200);
  Serial.println("Connected to Thread network");
  Serial.println("Waiting for Matter device discovery...");
  while (!matter_door_lock.is_online()) {
    delay(200);
  Serial.println("Matter device is now online");
  static bool locked_last = false;
  bool locked = matter_door_lock.is_locked();
  if (locked != locked_last) {
    locked_last = locked;
    if (locked) {
      Serial.println("Locked");
      digitalWrite(LED_BUILTIN, LED_BUILTIN_ACTIVE);
      Serial.println("Unlocked");
  if (button_pressed) {
    matter_door_lock.toggle();
  static uint32_t btn_last_press = 0;
  if (millis() < btn_last_press + 200) {
    return;
  btn_last_press = millis();
  button_pressed = true;
