I want to create a three-item menu: Verizon, T-Mobile, AT&T. Since the example uses LEDs, I'll do the same--except with a dropdown menu to select among the three.
I'm trying to combine these two examples:
- Build an ESP8266 Web Server - Code and Schematics (NodeMCU) | Random Nerd Tutorials
- W3Schools Tryit Editor
Except with phone carriers instead of cars:
I'm struggling on the polyglot part of the programming, combining the HTML and Arduino program in the middle:
// Web Page Heading
client.println("<form action='/action_page.php'>");
client.println(" <select id='providor' name='providor'>");
client.println(" <option value='verizon'>Verizon</option>");
client.println(" <option value='tmobile'>T-Mobile</option>");
client.println(" <option value='atnt'>AT&T</option>");
client.println(" </select>");
client.println(" <input type='submit'>");
client.println("</form>");
if (providor==verizon)
client.println("<p>Providor Selected: Verizon</p>");
else if (providor==tmobile)
client.println("<p>Providor Selected: T-Mobile"</p>");
else if (providor==atnt)
client.println("<p>Providor Selected: AT&T"</p>");
Here is the rest of the program:
Based from
https://randomnerdtutorials.com/esp8266-web-server
HTML tool
https://www.w3schools.com/html/tryit.asp?filename=tryhtml_elem_select
#include <ESP8266WiFi.h>
// Replace with your network credentials
const char* ssid = "REPLACE_WITH_YOUR_SSID";
const char* password = "REPLACE_WITH_YOUR_PASSWORD";
// Set web server port number to 80
WiFiServer server(80);
// Variable to store the HTTP request
String header;
// Auxiliar variables to store the current output state
//String output5State = "off";
//String output4State = "off";
// Assign output variables to GPIO pins
const int output5 = 14; // D5 verizon
const int output6 = 12; // D6 tmobile
const int output7 = 13; // D7 atnt
// Current time
unsigned long currentTime = millis();
// Previous time
unsigned long previousTime = 0;
// Define timeout time in milliseconds (example: 2000ms = 2s)
const long timeoutTime = 2000;
// Initialize the output variables as outputs
pinMode(output5, OUTPUT);
pinMode(output6, OUTPUT);
pinMode(output7, OUTPUT);
// Set outputs to LOW
digitalWrite(output5, LOW);
digitalWrite(output6, LOW);
digitalWrite(output7, LOW);
// Connect to Wi-Fi network with SSID and password
Serial.print("Connecting to ");
Serial.println(ssid);
WiFi.begin(ssid, password);
Serial.print(".");
// Print local IP address and start web server
Serial.println("");
Serial.println("WiFi connected.");
Serial.println("IP address: ");
server.begin();
WiFiClient client = server.available(); // Listen for incoming clients
if (client) { // If a new client connects,
Serial.println("New Client."); // print a message out in the serial port
String currentLine = ""; // make a String to hold incoming data from the client
previousTime = currentTime;
while (client.connected() && currentTime - previousTime <= timeoutTime) { // loop while the client's connected
if (client.available()) { // if there's bytes to read from the client,
char c = client.read(); // read a byte, then
Serial.write(c); // print it out the serial monitor
header += c;
if (c == '\n') { // if the byte is a newline character
// if the current line is blank, you got two newline characters in a row.
// that's the end of the client HTTP request, so send a response:
if (currentLine.length() == 0) {
// HTTP headers always start with a response code (e.g. HTTP/1.1 200 OK)
// and a content-type so the client knows what's coming, then a blank line:
client.println("Content-type:text/html");
client.println("Connection: close");
client.println();
// turns the GPIOs on and off
if (header.indexOf("GET /5/on") >= 0)
Serial.println("D5 on");
output5State = "on";
digitalWrite(output5, HIGH);
else if (header.indexOf("GET /5/off") >= 0)
Serial.println("D5 off");
else if (header.indexOf("GET /6/on") >= 0)
Serial.println("D6 on");
output4State = "on";
digitalWrite(output6, HIGH);
else if (header.indexOf("GET /6/off") >= 0)
Serial.println("D6 off");
else if (header.indexOf("GET /7/on") >= 0)
Serial.println("D7 on");
digitalWrite(output7, HIGH);
else if (header.indexOf("GET /7/off") >= 0)
Serial.println("D7 off");
// Display the HTML web page
client.println("<!DOCTYPE html><html>");
client.println("<head><meta name=\"viewport\" content=\"width=device-width, initial-scale=1\">");
client.println("<link rel=\"icon\" href=\"data:,\">");
// CSS to style the on/off buttons
// Feel free to change the background-color and font-size attributes to fit your preferences
client.println("<style>html { font-family: Helvetica; display: inline-block; margin: 0px auto; text-align: center;}");
client.println(".button { background-color: #195B6A; border: none; color: white; padding: 16px 40px;");
client.println("text-decoration: none; font-size: 30px; margin: 2px; cursor: pointer;}");
client.println(".button2 {background-color: #77878A;}</style></head>");
// HERE
// Web Page Heading
client.println("</body></html>");
// The HTTP response ends with another blank line
client.println();
// Break out of the while loop
} else { // if you got a newline, then clear currentLine
currentLine = "";
} else if (c != '\r') { // if you got anything else but a carriage return character,
currentLine += c; // add it to the end of the currentLine
// Clear the header variable
header = "";
// Close the connection
client.stop();
Serial.println("Client disconnected.");
Serial.println("");
Any suggestions or solutions on how to change or the correct code?
