Hello evrybody
I hope your are going well!
I would like to improve my code for my meteo stations.
My stations take serveral measures and for each measure, a fonction is called
get_temperature()
get_humidity()
get_pressure()
get_sun();
get_wind();
get_battery();
get_luminosity()
and more...
my OLED (128x64) can only show 5 lines, then I need to make pages.
The problem, some sensors can be actuve or not, then I can give an index for a sensor.
get_temperature() can be the fist function called, but if the temperature is inactive, get_humidity() is the first called function
here is an exemple of page1
temperature: 26°C
humidity: 44%
pressure:90
battery:4.1V
As you can see, there is text, number and number with comma for each line
The idea is at the end of each function I save the text/value into a array of a strcut
get_temperature()
// Here is the code to get the value from the sensor
// Print the value
oled.print("Temperature: ");
oled.print(tmp);
oled.print("°C");
oled.display();
// Add here the code to save the text and the value into the first line of the page 1
I need to save the text and the value into a page at a line. Because, when my station sleep, I have a press button. When I press it, it wake up the sensors a show the page 1. When I press is again it showes the page 2, when I press it showes the page 3, and if there is no page 3, it show the page 1.
My problem is how to assign a measure form one of the function to a page and line free, dynamicly, keeping in mind that a sensor can be inactive. It meen, pressure, can be at line 3, or 1 or 4....
Do you see?
I started by writing a"draft" scruct (I have not tested it yet)
struct init_lignes { // for DS18B20 calibration
char ligne1;
int16_t value1;
char ligne2;
int16_t value2;
char ligne3;
int16_t value3;
char ligne4;
int16_t value4;
char ligne5;
int16_t value5;
struct init_pages
init_lignes ligne1;
init_lignes page2;
init_lignes page3;
init_pages pages;
but it does not help a lot, as we never now on wich line a measure will be.
I wonder if you have an idea how to do that at the end of function?
A human word, I would say
If a line is free on the first page, save the value, or look for the next line free. IF all line of the page 1 is busy, look to save on the page 2 or 3...
How would you do it in Arduino language???
How sould I start?
many THANKS
