how to create robot car with sensor temp ??
i was there to make a robot car project using arduino with temp.sensor....
can anyone help what kind of tools and code program???
With a temporary sensor? Wouldn't a permanent one make more sense?
can anyone help
Sure. I'll be right over. Where do you live?
what kind of tools
A chainsaw and an ox-acetelene torch, to start with. A CNC mill is almost essential, too.
and code program?
What is the robot car supposed to do?
make a robot car fire but use a fan instead of water ...
That's a good idea. If you use water, you'll put the fire out. Using a fan to make it spread is a much better idea. Before long, your whole robot will be burned up, and you can move on to projects that make sense.
no no no im sorry for that stetment i was wrong...
my project measure the temperature in the room and if the temperature exceeds the set temperature then the fan will turn on ...
that's it i mean :slight_smile:
first i want a motor dc can be set start or stop using arduino....but i don't know the code programm :frowning: can help ?
How is the motor connected? Do you want just on/off or variable speed?
Some references that will be useful:
On/Off - http://arduino.cc/en/Reference/DigitalWrite
Variable speed - analogWrite() - Arduino Reference
thanks before , but i was try with motor dc is not connected … what is using transistor ???
