How to create plugin for Arduino IDE?
I require the format and steps necessary. I have basic knowledge on Java.
I have a tools directory in the installation directory with the Mangler example and a howto.txt.
The documentation is about processing, but I think it will work for the Ardunio IDE likewise.
TOOLS IN PROCESSING
With initial help from code contributed by fjen, Processing release 0147 and
later have a dynamically loading tools menu, which can be used to expand the
environment in fun and fantastic ways.A Tool is a chunk of code that runs from the Tools menu. Tools are a means
of building onto the Processing Development Environment without needing to
rebuild the beast from source.The interface (at least for now) is extremely simple:
package processing.app.tools.Tool;
public interface Tool extends Runnable {
public void init(Editor editor);
public void run();
public String getMenuTitle();
Whandall:
Thanks for reply but can you clarify a little.
Arduino stems from Wiring, the hardware side of Processing.
I think the tools interface is common to all three systems.
I want to create a jar file.
I need to know about any library or something?
I am not familiar with processing.
Any resource link to start with?
You did not bother reading the howto.txt?
Processing (while not needed for a tool for Arduino) is found here https://processing.org/.
Whandall:
You did not bother reading the howto.txt?Processing (while not needed for a tool for Arduino) is found here https://processing.org/.
I read your quote there. But how do I implement init(Editor editor)? I don't get the structure fully. Any example of source code?
Thanks in advance.
Mangler is an example.
subhajitdas298:
What's your plugin going to do?
