how to cycle between 4 current sensor values on the LCD?
I'm doing this project to cycle current sensor values detect through the sensor that is diplayed into the LCD, but i'm trying to cycle them between each other? help me pls! :slight_smile:
Attached is my work so far that can display only 1 value.
display.ino (800 Bytes)
Welcome to the forum.
http://forum.arduino.cc/index.php/topic,148850.0.html then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
Thanks.. Tom.. :slight_smile:
This page has a list of lcd functions.
These ones might be important to you.
lcd.clear(); // clears the LCD
lcd.setCursor(0, 0); // first position, first line
lcd.setCursor(0, 1); // first position, second line
Lines like "Current is:" can be printed in void setup()
Then the actual current value can be printed to a certain position, like this.
lcd.setCursor(6, 1); // seventh position, second line
lcd.print(current, 1); // print with one decimal place
Start with a simple delay between prints.
Then upgrade to a non-blocking delay as explained in the BlinkWithoutDelay sketch that comes with the IDE.
Leo..
