How to deal with analog pins on arduino mega?
hi all,
for managing a modelrailway project, i wrote a tool-sketch for testing
all peripherie
as mega has more than 8 analog pins, simply i wrote A11, A12..
that does not work !
i a similar thread i found this
const byte pinAssign[16] ={A0, A1, A2 , A3 , A4, A5, A6,A7,
                         A8, A9,A10,A11,A12,A13,A14,A15};
but compiler tells me 'A8 was not declared in this scope..
this row is positioned before setup, so guess its global !?
how to correctly adress the pin-numbers higher than A7 ?
Did you forget to select the correct board? This happily compiles for a Mega
const byte pinAssign[16] = {A0, A1, A2 , A3 , A4, A5, A6, A7,
                            A8, A9, A10, A11, A12, A13, A14, A15
thanks,
thats what was !
now the higher pins are accepted !
Before i had some other issues tried with nano and forgot
to switch over:-))
