How to debug this code so that my accelerometer will work?
#include <Adafruit_LSM6DS.h>
#include <Adafruit_LSM6DSO32.h>
#include <Adafruit_LSM6DSOX.h>
#include <Adafruit_LSM6DS3.h>
#include <Adafruit_LSM6DS33.h>
#include <Adafruit_LSM6DSL.h>
#include <Adafruit_ISM330DHCX.h>
//#include <SparkFunLSM6DS3.h>
#include <Wire.h>
// For graphics libraries
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 64 // OLED display height, in pixels
// Declaration for an SSD1306 display connected to I2C (SDA, SCL pins)
#define OLED_RESET -1 // Reset pin # (or -1 if sharing Arduino reset pin)
//Adafruit_SSD1306 _display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
#define OLED_ADDR 0x3C
// For accelerometer
#include <Arduino_LSM6DS3.h>
#include <Adafruit_Sensor.h>
//#include <Adafruit_LIS3DH.h>
// Used for LIS3DH hardware & software SPI
//#define _lsm6ds3
Adafruit_LSM6DS3 _lsm6ds3 = Adafruit_LSM6DS3();
//Adafruit_LSM6DS3 myIMU(I2C_MODE, 0x6A);
enum BrushType {
CIRCLE,
SQUARE,
TRIANGLE,
NUM_BRUSH_TYPES
BrushType _curBrushType = CIRCLE;
enum BrushFillMode {
FILL,
OUTLINE,
NUM_FILL_MODES
BrushFillMode _curBrushFillMode = FILL;
const int BRUSH_SELECTION_BUTTON_PIN = 8;
const int BRUSH_FILLMODE_BUTTON_PIN = 6;
const int CLEAR_DRAWING_BUTTON_PIN = 7;
const int BRUSH_SIZE_ANALOG_INPUT = A3;
// change to 1023 with 10-bit ADC, 4095 if using 12-bit ADC
const int MAX_ANALOG_VAL = 1023;
int _lastShapeSelectionButtonVal = HIGH;
int _lastDrawModeButtonVal = HIGH;
int _lastClearDrawingButtonVal = HIGH;
const long BAUD_RATE = 115200;
float _xBrushCursorCenter;
float _yBrushCursorCenter;
int _brushCursorSize = 10;
Serial.begin(BAUD_RATE);
pinMode(BRUSH_SELECTION_BUTTON_PIN, INPUT_PULLUP);
pinMode(BRUSH_FILLMODE_BUTTON_PIN, INPUT_PULLUP);
pinMode(CLEAR_DRAWING_BUTTON_PIN, INPUT_PULLUP);
// SSD1306_SWITCHCAPVCC = generate display voltage from 3.3V internally
if (!_display.begin(SSD1306_SWITCHCAPVCC, 0x3C)) { // Address 0x3D for 128x64
Serial.println("SSD1306 allocation failed");
for (;;); // Don't proceed, loop forever
if (!IMU.begin()) {
  Serial.println("Failed to initiliaze IMU");
  while (true);
// IMU.setAccelRange(LSM6DS_RANGE_2_G); // 2, 4, 8 or 16 G!
_display.clearDisplay();
_display.setTextSize(1); // Normal 1:1 pixel scale
_display.setTextColor(SSD1306_WHITE); // Draw white text
_display.setCursor(0, 0); // Start at top-left corner
_display.print("Waiting to receive\ndata from serial...");
_display.println("\n");
_display.print("Baud rate:");
_display.print(BAUD_RATE);
_display.print(" bps");
_display.display();
float x, y, z;
int degreesX = 0;
int degreesY = 0;
// Initialize accelerometer
if (IMU.accelerationAvailable()) {
IMU.readAcceleration(x, y, z);
if (x > 0.1) {
x = 100 * x;
degreesX = map(x, 0, 97, 0, 90);
Serial.print("Tilting up ");
Serial.print(degreesX);
Serial.println(" degrees");
if (x < -0.1) {
x = 100 * x;
degreesX = map(x, 0, -100, 0, 90);
Serial.print("Tilting down ");
if (y > 0.1) {
y = 100 * y;
degreesY = map(y, 0, 97, 0, 90);
Serial.print("Tilting left ");
Serial.print(degreesY);
if (y < -0.1) {
y = 100 * y;
degreesY = map(y, 0, -100, 0, 90);
Serial.print("Tilting right ");
checkAndParseSerial();
readBrushButtons();
if (checkClearDrawingButton()) {
// if we're here, clear drawing button pressed
// draw clear to screen
_display.setTextSize(3);
int16_t x1, y1;
uint16_t wText, hText;
const String strCleared = "CLEARED";
const String strDrawing = "DRAWING";
int xCenter = _display.width() / 2;
int yCenter = _display.height() / 2;
_display.getTextBounds(strCleared, 0, 0, &x1, &y1, &wText, &hText);
int yText = yCenter - hText;
_display.setCursor(xCenter - wText / 2, yText);
_display.print(strCleared);
yText += hText + 3;
_display.getTextBounds(strDrawing, 0, 0, &x1, &y1, &wText, &hText);
_display.print(strDrawing);
_display.display();
Serial.println("cls");
readAccelAndUpdateBrushCursorLocation();
// Normalize ball location (in terms of fraction of screen)
int halfSize = _brushCursorSize / 2;
float xFrac = (_xBrushCursorCenter - halfSize) / (float)(_display.width() - 2 * halfSize);
float yFrac = (_yBrushCursorCenter - halfSize) / (float)(_display.height() - 2 * halfSize);
// Read brush size
int sizeVal = analogRead(BRUSH_SIZE_ANALOG_INPUT);
float sizeFrac = sizeVal / (float)(MAX_ANALOG_VAL);
// Draw values to screen for x, y
// draw brush info
drawBrushInfo(xFrac, yFrac, sizeFrac);
// draw brush location
drawBrushCursor(_xBrushCursorCenter, _yBrushCursorCenter, _brushCursorSize);
_display.display();
// Transmit the data
Serial.print(xFrac, 4);
Serial.print(",");
Serial.print(yFrac, 4);
Serial.print(",");
Serial.print(sizeFrac, 4);
Serial.print(",");
Serial.print(_curBrushType);
Serial.print(", ");
Serial.println(_curBrushFillMode);
delay(20);
Draws the brush cursor location on the OLED
void drawBrushCursor(float xCursorCenter, float yCursorCenter, int cursorSize) {
int halfSize = cursorSize / 2;
int xCursorLeft = xCursorCenter - halfSize;
int yCursorTop = yCursorCenter - halfSize;
int fillColor = SSD1306_BLACK;
int outlineColor = SSD1306_WHITE;
if (_curBrushFillMode == FILL) {
fillColor = SSD1306_WHITE;
outlineColor = SSD1306_BLACK;
if (_curBrushType == CIRCLE) {
// Draw brush location
_display.fillCircle(xCursorCenter, yCursorCenter, halfSize, fillColor);
_display.drawCircle(xCursorCenter, yCursorCenter, halfSize, outlineColor);
} else if (_curBrushType == SQUARE) {
_display.fillRect(xCursorLeft, yCursorTop, cursorSize + 1, cursorSize + 1, fillColor);
_display.drawRect(xCursorLeft, yCursorTop, cursorSize + 1, cursorSize + 1, outlineColor);
} else if (_curBrushType == TRIANGLE) {
int x1 = xCursorCenter - halfSize;
int y1 = yCursorCenter + halfSize;
int x2 = xCursorCenter;
int y2 = yCursorCenter - halfSize;
int x3 = xCursorCenter + halfSize;
int y3 = y1;
_display.fillTriangle(x1, y1, x2, y2, x3, y3, fillColor);
_display.drawTriangle(x1, y1, x2, y2, x3, y3, outlineColor);
int lineColor = SSD1306_WHITE;
// don't draw crosshair for triangle (it looks bad!)
if (_curBrushType != TRIANGLE) {
_display.drawLine(xCursorCenter - halfSize, yCursorCenter, xCursorCenter + halfSize, yCursorCenter, lineColor);
_display.drawLine(xCursorCenter, yCursorCenter - halfSize, xCursorCenter, yCursorCenter + halfSize, lineColor);
void drawBrushInfo(float xFrac, float yFrac, float sizeFrac) {
const int CHAR_HEIGHT = 8;
const int MAX_MARGIN = (2 * CHAR_HEIGHT) + 2;
const int MAX_BRUSH_SIZE = min(_display.width() - MAX_MARGIN, _display.height() - MAX_MARGIN);
int brushSize = sizeFrac * MAX_BRUSH_SIZE;
int halfBrushSize = brushSize / 2;
int xLeft = xCenter - halfBrushSize;
int yTop = yCenter - halfBrushSize;
String strBrushInfo;
strBrushInfo = "Circle: ";
_display.fillRoundRect(xLeft, yTop, brushSize, brushSize, halfBrushSize, SSD1306_WHITE);
_display.drawRoundRect(xLeft, yTop, brushSize, brushSize, halfBrushSize, SSD1306_WHITE);
strBrushInfo = "Square: ";
_display.fillRect(xLeft, yTop, brushSize, brushSize, SSD1306_WHITE);
_display.drawRect(xLeft, yTop, brushSize, brushSize, SSD1306_WHITE);
strBrushInfo = "Triangle: ";
int x1 = xCenter - halfBrushSize;
int y1 = yCenter + halfBrushSize;
int x2 = xCenter;
int y2 = yCenter - halfBrushSize;
int x3 = xCenter + halfBrushSize;
int y3 = y1;
  _display.fillTriangle(x1, y1, x2, y2, x3, y3, SSD1306_WHITE);
  _display.drawTriangle(x1, y1, x2, y2, x3, y3, SSD1306_WHITE);
strBrushInfo += "Fill";
strBrushInfo += "Outline";
// Print out brush info
int16_t x1, y1;
_display.getTextBounds(strBrushInfo, 0, 0, &x1, &y1, &wText, &hText);
_display.setCursor(xCenter - wText / 2, 0);
_display.print(strBrushInfo);
// Print out brush size beneath shape
_display.getTextBounds("X.XXX", 0, 0, &x1, &y1, &wText, &hText);
_display.setCursor(xCenter - wText / 2, yCenter + halfBrushSize + 2);
_display.print(sizeFrac, 3);
Checks the serial port for new data. Expects comma separated text lines with
and
void checkAndParseSerial() {
// Check to see if there is any incoming serial data
if (Serial.available() > 0) {
// If we're here, then serial data has been received
// Read data off the serial port until we get to the endline delimiter ('\n')
// Store all of this data into a string
String rcvdSerialData = Serial.readStringUntil('\n');
// Parse out the comma separated string
int startIndex = 0;
int endIndex = rcvdSerialData.indexOf(',');
if (endIndex != -1) {
  // Parse out the shape type, which should be 0 (circle), 1 (square), 2 (triangle)
  String strBrushType = rcvdSerialData.substring(startIndex, endIndex);
  int brushType = strBrushType.toInt();
  _curBrushType = (BrushType)brushType;
  // Parse out draw mode 0 (fill), 1 (outline)
  startIndex = endIndex + 1;
  endIndex = rcvdSerialData.length();
  String strBrushFillMode = rcvdSerialData.substring(startIndex, endIndex);
  int brushFillMode = strBrushFillMode.toInt();
  _curBrushFillMode = (BrushFillMode)brushFillMode;
// Echo the data back on serial (for debugging purposes)
// Prefix debug output with '#' as a convention
Serial.print("# Arduino Received: '");
Serial.print(rcvdSerialData);
Serial.println("'");
void readAccelAndUpdateBrushCursorLocation() {
// Use Adafruit Sensor Library to get a normalized reading
// Adafruit_Sensor in Detail | Using the Adafruit Unified Sensor Driver | Adafruit Learning System
sensors_event_t event;
_lsm6ds3.getEvent(&event);
// Set new circle location based on accel
_xBrushCursorCenter = _xBrushCursorCenter + -event.acceleration.x;
_yBrushCursorCenter = _yBrushCursorCenter + event.acceleration.y;
// Check boundaries
if (_xBrushCursorCenter - halfSize < 0) {
_xBrushCursorCenter = halfSize;
} else if (_xBrushCursorCenter + halfSize >= _display.width()) {
_xBrushCursorCenter = _display.width() - halfSize - 1;
if (_yBrushCursorCenter - halfSize < 0) {
_yBrushCursorCenter = halfSize;
} else if (_yBrushCursorCenter + halfSize >= _display.height()) {
_yBrushCursorCenter = _display.height() - halfSize - 1;
bool checkClearDrawingButton() {
// Read the clear button val and write out to serial if active
int clearDrawingButtonVal = digitalRead(CLEAR_DRAWING_BUTTON_PIN);
bool buttonPress = false;
if (clearDrawingButtonVal == LOW && clearDrawingButtonVal != _lastClearDrawingButtonVal) {
buttonPress = true;
_lastClearDrawingButtonVal = clearDrawingButtonVal;
return buttonPress;
Check the shape selection and draw mode buttons and update the global
variables _curBrushType and _curDrawMode accordingly
void readBrushButtons() {
// Read the shape selection button (active LOW)
int shapeSelectionButtonVal = digitalRead(BRUSH_SELECTION_BUTTON_PIN);
if (shapeSelectionButtonVal == LOW && shapeSelectionButtonVal != _lastShapeSelectionButtonVal) {
// Increment the shape type
_curBrushType = (BrushType)((int)_curBrushType + 1);
// Reset back to CIRCLE if we've made it to NUM_SHAPE_TYPES
if (_curBrushType >= NUM_BRUSH_TYPES) {
// Read the shape draw mode button val (active LOW)
int shapeDrawModeButtonVal = digitalRead(BRUSH_FILLMODE_BUTTON_PIN);
if (shapeDrawModeButtonVal == LOW && shapeDrawModeButtonVal != _lastDrawModeButtonVal) {
// Increment the draw mode
_curBrushFillMode = (BrushFillMode)((int)_curBrushFillMode + 1);
// Reset back to FILL if we've made it to NUM_DRAW_MODES
if (_curBrushFillMode >= NUM_FILL_MODES) {
// Set last button values (so nothing happens if user just holds down a button)
_lastShapeSelectionButtonVal = shapeSelectionButtonVal;
_lastDrawModeButtonVal = shapeDrawModeButtonVal;
Use code tags (the </> icon above the compose window) to make it easier to read and copy for examination
Hi, @steamedbun
Welcome to the forum.
First question;
  1. What model Arduino controller are you using?
  2. What hardware, peripherals, links to spec/data, are you using?
  3. Does your code compile?
  4. What is your code supposed to do?
  5. What does your code do?
  6. Have you written your code in stages?
  7. If so, have you got code working that JUST communicates with the accelerometer to prove you can get readings from it?
Thanks.. Tom.. :grinning: :+1: :coffee: :australia:
