How to debug WiFi connection disconnects
I get some data through the GPIOs of a ESP8266 and save
them on a mobile phone which is connected to a WLAN access point (WiFi.softAP) on the ESP8266.
The problem is, if the ESP8266 is in actual use, the WLAN connection between the
ESP8266 and the mobile phone persists only for 5 to 20 seconds.
I have already enabled WiFi debug in Arduino IDE, the problem is, you can only
send the debug output to a Serial.
But if I connect the ESP8266 through usb with a computer or a mobile phone,
there are no wlan disconnects at all.
Therefore in order to find the reason for the disconnects, it would be useful to send the debug output to a file on the ESP8266.
Could this also
be a problem if you use: while ( swSerial.available() > 0 ) { rb = swSerial.read(); }
how do you power it?
With a akku.
I also thought of voltage fluctuation or that the wlan signal is shielded by the case (a plastic box) where the ESP8266 is in it.
nuon:
With a akku.
So power it differently and see if the problem persists, the ESP takes quite a lot of power and the first thing to go is the WIFI which can demand up to 250mA. You may also just add a big capacitor to deal with current spikes.
nuon:
Nope that's not it
Does it make sense to monitor the voltage with ESP.getVcc()?
Is it precise enough to find such a voltage decrease that possibly causes the wlan disconnects?
What would be the minimum voltage for a stable wlan connection?
