PeterH:
adrian_h:
If you have better solutions, please bring them forward.
I've already said what the right solution is.
What you have basically said is to go look it up to a person who is asking for help without making any suggestions as to where to get such information, except "the internet". Good job.
PeterH:
I appreciate that you're trying to help, but you're giving bad advice, presumably because you don't know better. Creating a program consisting of multiple source files is something that is done routinely in 'C'/C++ and there is no need for you to speculate about whether you need 'extern' and/or 'const' and whether your declarations and/or definitions should go in header or source files and so on.
I do know better. If I were to use a real IDE and a project was worth the trouble, I would go on about how to use header files in general. This however is a small project not requiring this level of information. If the OP really needs it, s/he will ask.
PeterH:
Don't put your definitions in header files as you suggested - that will lead to duplicated symbol definitions as soon as you need to share data between modules. Don't put your declarations in the client code as you suggested - that will lead to duplication of the declarations which reduces maintainability and can introduce some very nasty bugs.
Actually, no, it won't. You can put constants in a header file without that problem. This allows for compiler optimization and meta-template programming.
PeterH:
The right way to do it is to put your definitions in a .c/.cpp file and the corresponding external declarations in a .h file. Any client code needing visibility of the declarations in a module can then simply include the appropriate header. The language and development tools have been designed around this simple scheme which works for programs from a handful of lines of code up to hundreds of millions of lines of code. The fact you can flout this convention and still get code to compile in simple situations doesn't mean it's a good idea and doesn't mean that you should be recommending that approach to novices asking for advice about how to do this.
If these were not constant, then yes, that IS the way to do it. This doesn't break things as you scale up when using C++.
PeterH:
If you don't know what declarations and definitions are or how these should be coded then look for examples. There countless examples in the internet and plenty of good examples in the Arduino runtime library itself.
Countless, yes. However, you don't really state anything that is useful. No real direction except waving your hand and saying "go that way". To reiterate, my response is for SIMPLICITY. If the people here really want to get into it, they would read books like the ones listed here: c++ faq - The Definitive C++ Book Guide and List - Stack Overflow, go for schooling in programming and ask more questions as they go along (which is the purpose of this forum).
Additional resources are:
