12king
September 14, 2022, 5:28pm
1
I am bit confused I send this request http://192.168.172.3:2001/detail?Id=1111 in postman and then I get following response from server in postman
json format
"USER": "IDS",
"Byte": {
"public_id": 62,
"communication": {
"user_id": 24,
"range": [
"no_1": "111"
"no_2": "222"
"no_3": "333"
"Internet": {
"user_id": 115,
"range": [
"no_1": "144"
"card_1": "1.1"
"InternetData": [
"id_1": 1,
"name_1": "rock",
"wait_1": 1
"id_2": 2,
"name_2": "devid",
"wait_2": 1
"id_3": 3,
"name_3": "dave",
"wait_3": 5
"id_4": 4,
"name_4": "stev",
"wait_4": 3
request header
// send HTTP request header
client.println("GET" + " " + PATH_NAME + String S("?Id=1111");" HTTP/1.1");
client.println("Host: " + String(HOST_NAME));
client.println("Connection: close");
client.println(); // end HTTP request header
I don't understand How to decode this type of server response ? Do I only need to
Deserialize ?
You may want to have a look at one of the JSON libraries. E.g.,
ArduinoJson is a JSON library for Arduino, IoT, and any embedded C++ project. It supports JSON serialization, JSON deserialization, MessagePack, streams, and fixed memory allocation. It has a simple API, it’s easy to use, and it’s trusted by...
Deserializing is a start. The ArduinoJson 'Assistant' will show you how.
// Stream& input;
StaticJsonDocument<768> doc;
DeserializationError error = deserializeJson(doc, input);
if (error) {
Serial.print(F("deserializeJson() failed: "));
Serial.println(error.f_str());
return;
const char* USER = doc["USER"]; // "IDS"
JsonObject Byte = doc["Byte"];
int Byte_public_id = Byte["public_id"]; // 62
int Byte_communication_user_id = Byte["communication"]["user_id"]; // 24
JsonArray Byte_communication_range = Byte["communication"]["range"];
const char* Byte_communication_range_0_no_1 = Byte_communication_range[0]["no_1"]; // "111"
const char* Byte_communication_range_1_no_2 = Byte_communication_range[1]["no_2"]; // "222"
const char* Byte_communication_range_2_no_3 = Byte_communication_range[2]["no_3"]; // "333"
int Byte_Internet_user_id = Byte["Internet"]["user_id"]; // 115
const char* Byte_Internet_range_0_no_1 = Byte["Internet"]["range"][0]["no_1"]; // "144"
const char* Byte_Internet_range_1_card_1 = Byte["Internet"]["range"][1]["card_1"]; // "1.1"
JsonArray InternetData = doc["InternetData"];
JsonObject InternetData_0 = InternetData[0];
int InternetData_0_id_1 = InternetData_0["id_1"]; // 1
const char* InternetData_0_name_1 = InternetData_0["name_1"]; // "rock"
int InternetData_0_wait_1 = InternetData_0["wait_1"]; // 1
JsonObject InternetData_1 = InternetData[1];
int InternetData_1_id_2 = InternetData_1["id_2"]; // 2
const char* InternetData_1_name_2 = InternetData_1["name_2"]; // "devid"
int InternetData_1_wait_2 = InternetData_1["wait_2"]; // 1
JsonObject InternetData_2 = InternetData[2];
int InternetData_2_id_3 = InternetData_2["id_3"]; // 3
const char* InternetData_2_name_3 = InternetData_2["name_3"]; // "dave"
int InternetData_2_wait_3 = InternetData_2["wait_3"]; // 5
JsonObject InternetData_3 = InternetData[3];
int InternetData_3_id_4 = InternetData_3["id_4"]; // 4
const char* InternetData_3_name_4 = InternetData_3["name_4"]; // "stev"
int InternetData_3_wait_4 = InternetData_3["wait_4"]; // 3
lesept
September 14, 2022, 8:08pm
4
johnwasser:
It's here
Select your options, then paste your response : 2 clicks after, you get the code. Just keep the info you're looking for.
12king
September 15, 2022, 12:48am
5
Do I need to add the code of Deserialization in this way ?
#include <SPI.h>
#include <Ethernet.h>
#include <ArduinoJson.h>
const char* USER;
JsonObject Byte;
int Byte_public_id;
int Byte_communication_user_id ;
JsonArray Byte_communication_range;
const char* Byte_communication_range_0_no_1;
const char* Byte_communication_range_1_no_2;
const char* Byte_communication_range_2_no_3;
int Byte_Internet_user_id;
const char* Byte_Internet_range_0_no_1;
const char* Byte_Internet_range_1_card_1;
JsonArray InternetData;
JsonObject InternetData_0 ;
int InternetData_0_id_1;
const char* InternetData_0_name_1;
int InternetData_0_wait_1;
JsonObject InternetData_1;
int InternetData_1_id_2 ;
const char* InternetData_1_name_2 ;
int InternetData_1_wait_2;
JsonObject InternetData_2;
int InternetData_2_id_3 ;
const char* InternetData_2_name_3;
int InternetData_2_wait_3;
JsonObject InternetData_3;
int InternetData_3_id_4;
const char* InternetData_3_name_4;
int InternetData_3_wait_4;
// replace the MAC address below by the MAC address printed on a sticker on the Arduino Shield 2
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
EthernetClient client;
while (client.available())
// read an incoming byte from the server and print them to serial monitor:
char c = client.read();
Serial.print(c);
// Stream& input;
DeserializationError error = deserializeJson(doc, client);
if (error) {
return;
12king
September 15, 2022, 6:13am
6
why Byte_communication_range_0_no_1 variable printing 0 instead 111
#include <SPI.h>
const char* USER;
JsonObject Byte;
int Byte_public_id;
Serial.print(c);
// Stream& input;
if (error) {
return;
Serial.println(Byte_communication_range_0_no_1);
12king
September 17, 2022, 1:19pm
7
What does it means ?
18:40:33.215 -> connected
18:40:33.308 -> HdeserializeJson() failed: InvalidInput
18:40:33.400 -> 1deserializeJson() failed: InvalidInput
18:40:33.447 -> 2deserializeJson() failed: InvalidInput
18:40:33.447 -> OdeserializeJson() failed: InvalidInput
18:40:33.540 ->
18:40:33.540 -> deserializeJson() failed: InvalidInput
18:40:33.587 -> deserializeJson() failed: InvalidInput
18:40:33.634 -> SdeserializeJson() failed: InvalidInput
18:40:33.680 -> 2deserializeJson() failed: InvalidInput
18:40:33.726 -> 1deserializeJson() failed: InvalidInput
18:40:33.773 -> 1deserializeJson() failed: InvalidInput
18:40:33.819 -> 5deserializeJson() failed: InvalidInput
18:40:33.866 -> GdeserializeJson() failed: InvalidInput
18:40:33.912 ->
Looks like what you are passing to deserialize() is not a valid JSON document. If you send the characters you read from ‘client’ to Serial Monitor, does it look like a JSON document?
12king
September 17, 2022, 2:07pm
9
Does the error here show that the deserialization has not been successful?
I am attaching two test's result of serial monitor
test 1
18:40:33.540 ->
18:40:33.912 ->
18:40:33.912 -> deserializeJson() failed: InvalidInput
18:40:34.004 ->
18:40:34.004 -> deserializeJson() failed: InvalidInput
18:40:34.050 -> deserializeJson() failed: InvalidInput
18:40:34.050 ->
18:40:34.144 -> deserializeJson() failed: InvalidInput
18:40:34.144 -> jdeserializeJson() failed: InvalidInput
18:40:34.190 ->
18:40:34.237 -> true
18:40:34.237 -> 2
18:40:34.237 -> name
Test2
18:41:31.264 -> connected
18:41:31.358 -> HdeserializeJson() failed: InvalidInput
18:41:31.403 -> 1deserializeJson() failed: InvalidInput
18:41:31.449 -> 2deserializeJson() failed: InvalidInput
18:41:31.449 -> OdeserializeJson() failed: InvalidInput
18:41:31.542 ->
18:41:31.542 -> deserializeJson() failed: InvalidInput
18:41:31.587 -> deserializeJson() failed: InvalidInput
18:41:31.634 -> SdeserializeJson() failed: InvalidInput
18:41:31.681 -> 2deserializeJson() failed: InvalidInput
18:41:31.728 -> 1deserializeJson() failed: InvalidInput
18:41:31.774 -> 1deserializeJson() failed: InvalidInput
18:41:31.820 -> 4deserializeJson() failed: InvalidInput
18:41:31.866 -> GdeserializeJson() failed: InvalidInput
18:41:31.912 ->
18:41:31.912 -> deserializeJson() failed: InvalidInput
18:41:31.959 -> deserializeJson() failed: InvalidInput
18:41:32.005 ->
18:41:32.005 -> deserializeJson() failed: InvalidInput
18:41:32.052 -> deserializeJson() failed: InvalidInput
18:41:32.052 ->
18:41:32.145 -> deserializeJson() failed: InvalidInput
18:41:32.191 -> jdeserializeJson() failed: InvalidInput
18:41:32.191 ->
18:41:32.238 -> true
18:41:32.238 -> 2
18:41:32.238 -> name
Yes. It says “failed: Invalid Input”.
12king
September 17, 2022, 2:28pm
11
I am getting confused because I am getting the value along with the error message
18:41:32.238 -> 2
what message should be displayed after deserialization?
It looks like you are calling deserialize twenty times with invalid JSON before you call it with valid JSON.
system
Closed
March 16, 2023, 4:16pm
14
