How to decoded data which is of webserver data?
Hello,
Arduino can not encode data which has been received from webserver.
What you mean is that you can't write the code to do it. Not the same thing at all.
Vishvas:
Hello,
Can you please explain what the problem is ? Perhaps post an example of the data and what you want to do.
I just want to download a wav file from webserver and save into SD card, so I am not getting actual data of wav file by arduino esp8266 web server request.
So I have made a app in Node.js which is read data of wav file and encode it in base64 format then send into response of request which is called by arduino esp8266 web server
and then I am trying to decode those data for getting in actual data of wav file.
please let me know if you have still a query.
Thank you...
Why not? What code is running on the Arduino?
Using what code?
