Hi all, I have a project using a DFPlayer Mini and the DFPlayerMini_fast library. I can't figure out how to write the code to change the EQ setting. In the code below, I have no idea what to put between the parentheses after myMP3.EQSelect.
When I type that, it autocompletes with "uint8_t setting" (see below code), but I don't know how to actually call the specific EQ setting. In the library, it says that the value that I want is "const uint8_t EQ_BASE", but when I replace the word "setting" in the code below with EQ_BASE, I get "Compilation error: expected primary-expression before 'EQ_BASE'". So what am I doing wrong? Thanks in advance.
#include <DFPlayerMini_Fast.h>
#include <ezButton.h>
ezButton button(4);
int last_button_state = HIGH;
#if !defined(UBRR1H)
#include <SoftwareSerial.h>
SoftwareSerial mySerial(10, 11); // RX, TX
#endif
DFPlayerMini_Fast myMP3;
mySerial.begin(9600);
myMP3.begin(mySerial, true);
#else
Serial1.begin(9600);
myMP3.begin(Serial1, true);
#endif
Serial.println("Setting volume to 20");
myMP3.volume(20);
myMP3.EQSelect(uint8_t setting)
button.loop();
if (last_button_state == HIGH && button.getStateRaw() == LOW)
myMP3.play(1);
last_button_state = LOW;
if (button.isReleased())
