How to #define/#ifdefine
I have been searching through the internet for an example on how to use the #ifdef command. I am confident I don't fully understand how it works. From what I have read, #ifdef just checks to see if is defined. But I wish to check to see what it is defined as. For my application, I am constantly going from an 800x480 screen and a 320x240 screen. All I simply want to do is change the #define SCREEN so that way I am not going through the code and updating values nor am I having to make dual codes. I can make all changes to single sketch. So basically, what is the correct way to do the following? I am pretty sure it is obvious what it is I am trying to do, it is just not correct of course.
#define SCREEN  ITDB32S
#ifdef SCREEN
  if (SCREEN == ITDB50) {
    #define n 25
    #define X_c 745
    #define Y_c 457
    #define X_t 80
    #define Y_t 48
  else {
    #define n 10
    #define X_c 298
    #define Y_c 226
    #define X_t 32
    #define Y_t 24
#endif
#ifdef SCREEN
  #if (SCREEN == ITDB50)
    #define n 25
    #define X_c 745
    #define Y_c 457
    #define X_t 80
    #define Y_t 48
  #else
    #define n 10
    #define X_c 298
    #define Y_c 226
    #define X_t 32
    #define Y_t 24
  #endif
#endif
huh.....I didn't realize you basically used it the same way. Well...thank you very much!
