How to define sectors???
Hi!
I am making led costume project with Arduino and I want to know in programming - how to define different costume sectors to make programming faster and sketch shorter??? Example, how to define all leds which belongs to left arm or chest, right leg, shoes, gloves etc.?????
Hmm... from what I understand, do you want to turn on a few LEDs at the same time?
If it is this, there is a fast and very light way. Arduino UNO divides its I/O by ports (B, C, D).
Here's an image that explains it better...
As you can see, if you want to turn on for example 8 LEDs at the same time, you can use all the PORTD pins, which are pins 0-7.
With this code you can turn on 8 LEDs at the same time:
   DDRB = 0B11111111; // 0-7 OUTPUT
   PORTB = 0B11111111; // 0-7 HIGHT
   PORTB = 0B00000000; // 0-7 LOW
Be careful with pins 0 and 1, as you are using them you will not be able to use the Serial.print
This is just a vague example, this I think is the fastest way to activate a pin or sector of pins, and it does not spend almost any memory, but to do what you want (activate certain LEDs of a PORT, since I imagine you don't want to turn on 8 pins at the same time) you will have to know how to use and modify the PORT register to turn on one pin at a time.
The OP didn’t mention how the LEDs were connected (could be WSxxxx type devices), so launching into port manipulation could be premature.
I imagine they are just normal LEDs and he is trying to do some animation with them, and he realized that using digitalWrite wastes a lot of memory and some time. Using the PORT will save you a lot of memory, although you could go to some algorithm to do the animation, but I don't think it uses an algorithm.
l-stars:
Hi!
Which Arduino?
What LED hardware?
If you are using NeoPixels, I have a library that breaks a string of them into sectors just as you say. Each is programmed independently from the rest. Patterns can be repeated as well.
-jim lee
it depends on your existing sketch and your hardware, so you
  • should post your code in codetags.
  • make a schematic drawing which groups of LEDs you currently have.
One option could be to use arrays to store the LED information and a function which activates whatever array you are handing over
something like
const byte rightArm[]{2,4,34,42,121};
const byte leftFoot[]{1,33,37,39,43};
setLeds(rightArm, ON);
ToddL1962:
Which Arduino?
What LED hardware?
Arduino UNO and Arduino Mega 2560.
WS2815 LED strips.
noiasca:
it depends on your exiiting sketch and your hardware, so you
something like
const byte leftFoot{1,33,37,39,43};
Please, can You put some colors and delays in this code, so I know what its really looks like!
