how to delay the next servo command
hello i combined 2 codes that i found on the forum
it works great on the simulator but not prefect jet
its for a railroad crossing so when the train touch the button the code activates
the redlights will go flashing and the servo turns the barrier down from 90 to 180 degrees
works great
the next thing is the servo will reverse directly from 180 to 90 without any delay
how can i add a delay that the servo will pauze for 15sec and the lights will still flashes
and after 15sec the servo turns back from 180 to 90 and if done the lights go to "switch off state "
i hope you understand what i mean and that someone can help me
// constants won't change. Used here to set a pin number :
const int rood1 =  12;     // the number of the LED pin
const int rood2 =  10;     // the number of the LED pin
const int wit1 =  11;     // the number of the LED pin
const int switchPin = 1;    // the number of the switch pin
int switchState = 0;       // variable for reading the switch status
#include <Servo.h>
Servo myservo;  // create servo object to control a servo
// a maximum of eight servo objects can be created
int pos = 90;    // variable to store the servo position
 myservo.attach(9);  // attaches the servo on pin 9 to the servo object
 pinMode(rood1, OUTPUT);  // initialize the LED pin as an output:
 pinMode(rood2, OUTPUT);
 pinMode(wit1, OUTPUT);
 pinMode(switchPin, INPUT);  // initialize the pushbutton pin as an input:
 switchState = digitalRead(switchPin);   // read the state of the //pushbuttonvalue:
 if (switchState == HIGH)   //if the switch on:
 digitalWrite(wit1, LOW);     //white LED off
 digitalWrite(rood1, HIGH);   //red1 LED on
 digitalWrite(rood2, LOW);    //red2 LED off
 delay(200);                     //wait 400ms
 digitalWrite(rood1, LOW);    //red1 LED off
 digitalWrite(rood2, HIGH);   //red2 LED on
 delay(200);
 for(pos = 90; pos < 180; pos += 10)  // goes from 90 degrees to 180 degrees
 { // in steps of 10 degree
 myservo.write(pos);              // tell servo to go to position in variable 'pos'
 delay(200);                     //wait 200ms
 delay(200);                       // waits 200ms for the servo to reach the position
 { delay(200);                       // waits 200ms for the servo to reach the position
 { digitalWrite(wit1, LOW);     //white LED off
 delay(200);
 for (pos = 180; pos > 90; pos -= 10)  // goes from 180 degrees to 90 degrees
 if (switchState == LOW)              //if the switch off
 digitalWrite(wit1, HIGH);    //white LED on
 delay(600);                  //wait 600ms
youtube video of the simulation
evinc: it works great on the simulator but not prefect jet
here where i live, as a train approaches a signal, this is what happens:
the crossing lights begin to flash the barrier is lowered (lights still flashing) the train clears the intersection . (lights still flashing) the barriers are raised . (lights still flashing) the lights stop their flashing
so, you want the lights to flash while the barrier is raised or lowered, yes?
you have to learn to program those 5 states without using delay...
in holland we have crossing where the white/yellow light stays flashing for attention/safety by night
so red flashing on barrier down
white/yellow flashing slower when barriers are up
evinc: in holland we have crossing where the white/yellow light stays flashing for attention/safety by night
so, still 5 states...
yeah 5 states
but im totally new with this so i did not learn anything buy some things today sensors wires resistors ect ect
(total noob) :)
just search things and combined them to get what i think i needed :)
without learning :P think thats my handicap :) just try and learn :P
evinc: yeah 5 states
(total noob) :)
yes, try...
My suggestion is that you learn how to flash the LEDs without using delay.
Moving the servo is harder, but you can get help there.
Look at the "blink without delay" example in the IDE's File->Example->Digital section
It will help you understand how to use millis() function to make things happen.
BulldogLowell: yes, try...
oke after some reading and trying i got this for the lights now
if the train hits the button it flashes and if it lost it the lights go's out
const int red1 = 13;
const int red2 = 12;
const int train = 7;
int red1State = LOW;
int red2State = LOW;
int trainState = LOW;
unsigned long previousMillis = 0;
const long interval = 1000;
    pinMode(red1, OUTPUT);
    pinMode(red2, OUTPUT);
    pinMode(train, INPUT);
{   trainState = digitalRead(train);
    if (trainState == HIGH)
        if (currentMillis - previousMillis >= interval)
            if (red1State == LOW)
                red1State = HIGH;
                red2State = LOW;
                red1State = LOW;
                red2State = HIGH;}
        digitalWrite(red1, red1State);
        digitalWrite(red2, red2State);
    else {  red1State = LOW;
        red2State = LOW;
        digitalWrite(train, trainState);}
