How to delay with out the use of delay?
Hey,
I am trying to make keypad on a touch screen LCD. I managed to get the visual part of it down and am a little stuck on getting the buttons to behave the way I want when clicked.
I can detect touch and look for touch in specified areas (x min - x max && y min - y max), but my problem is that when it does detect touch in specified areas, it spams it as long as it is pressed down.
When you add the "delay(1000);' to the code, it still spams it but now it just takes longer to spam because it is also spamming the delays.
I would like to Serial.writeln("1"); only to be sent once when the 1 button is clicked and or held down. I have tried using millis() but was still not getting expected output.
Does anyone know how to work around this?
  //==> see if there's any  touch data for us
  if(!screen.bufferEmpty())
    //==> retrieve the point
    TS_Point point = screen.getPoint();
    //==> map the point
    int x = map(point.x, screen_minx, screen_maxx, 0, touch.width());
    int y = map(point.y, screen_miny, screen_maxy, 0, touch.height());
    //if clicked in this area do this
    if((x > one_fx) && (x < (one_fx + one_fw))) { // x > 0 && x < 80
      if((y > one_fy) && (y <= (one_fy + one_fh))) { // y > 83 && y < 143
        Serial.println("1");
  } //==> touch check end if
} //==> void loop end
stay in a "do - while" loop as long as you detect the screen is touched
when released Serial.print("whatever has been pressed")
My two cents... just make a boolean variable so when the key is pressed the first time it sets key pressed to True. While key pressed is True, don't check for key presses. Reset key pressed to False after a specified number of milliseconds.
luxxtek:
mainlin:
I must be making some type of logic error, now when ever i press the button.. it spams it until I click an area outside of the buttons IF x/y range.
Here it is with do-loop and pressed boolean
  int x , y;
  boolean  pressed = false;
  //==> check for press
  do {
    //==> map the point
    x = map(point.x, screenminx, screenmaxx, 0, touch.width());
    y = map(point.y, screenminy, screenmaxy, 0, touch.height());
    pressed = true;
  } while(!screen.bufferEmpty() && pressed == false);
  if((x > one_fx) && (x < (one_fx + one_fw)) && (pressed == true)) { // x > 0 && x < 80
        Serial.print("1: x= ");
        Serial.print(x);
        Serial.print(" y= ");
        Serial.print(y);
        Serial.print("\n");
Try this.....
  int x , y;
  do {
    //==> map the point
    pressed = true;
  } while(!screen.bufferEmpty());
        Serial.print(x);
        Serial.print(y);
        Serial.print("\n");
        pressed= false;
Caution..... sometimes the last xy point returned by the touch screen is -1 !!!!
I would check for a valid point.x+point.x before mapping x+y.
