How to delete IR controls, Add in IMU comment out LCD
I’m learning for sure. in another thread the suggestions for getting rid of errors are helping me gain insight on the programming world.
in the stewart platform code below (dont know that it even works to begin with btw), i’d like to operate the stewart platform via IMU. get it in a self leveling or stabilizing platform operation.
I dont need the IR controls and dont need the LCD. I’d like to comment out the LCD code - so I can go on to learn how to incorporate it into the project later.
to Start, can I just go in and delete lines (or perhaps comment them out ) associated with the IR controls?
/* <Controlling code for Arduino Controlled Rotary Stewart Platform>
    Copyright (C) <2014>  <Tomas Korgo>
    This program is free software: you can redistribute it and/or modify
    it under the terms of the GNU General Public License as published by
    the Free Software Foundation, either version 3 of the License, or
    (at your option) any later version.
    This program is distributed in the hope that it will be useful,
    but WITHOUT ANY WARRANTY; without even the implied warranty of
    MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
    GNU General Public License for more details.
    You should have received a copy of the GNU General Public License
    along with this program.  If not, see <http://www.gnu.org/licenses/>.*/
#include <Servo.h>
#include <Wire.h>
#include <IRremote.h>
#include <LCD.h>
//define values of IrDA codes send from used remote control
#define MUTE_BUTTON 0x807F906F
#define STANDBY_ON 0x807F20DF
#define VOL_UP 0x807F609F
#define VOL_DOWN 0x807FA05F
#define DVD 0x807F08F7
#define TV 0x807F8877
#define GAME 0x807F48B7
#define CD 0x807FC837
//define of characters used for control of serial communication ['0'-'8']
#define SETBACKOFF 48
#define SETBACKON 49
#define SETPOSITIONS 50
#define PRINTPOS 51
#define STOPPRINTPOS 52
#define SWITCHIRDA 53
#define SETPOSITIONSINMS 54
#define SWITCHIRDAOFF 55
#define GEPOSITION 56
//defines of LCD pin numbers, most probably they dont have to be changed except of I2C_ADDR which value is neccessary and have to be changed.
#define I2C_ADDR 0x27
#define LCD 1
#define IrDA 1
#define BACKLIGHT_PIN 3
#define En 2
#define Rw 1
#define Rs 0
#define D4 4
#define D5 5
#define D6 6
#define D7 7
//MIN and MAX PWM pulse sizes, they can be found in servo documentation
#define MAX 2200
#define MIN 800
//Positions of servos mounted in opposite direction
#define INV1 1
#define INV2 3
#define INV3 5
//constants for computation of positions of connection points
#define pi  3.14159
#define deg2rad 180/pi
#define deg30 pi/6
//variables used for proper show of positions on LCD
char shown=0, showPos=0, useIrda=0;
unsigned long time;
//variable to store connected LCD
LiquidCrystal_I2C lcd(I2C_ADDR, En, Rw, Rs, D4,D5,D6,D7);
//IrReciever variables
IRrecv irrecv(12); // Receive Ir on digital pin n 12
decode_results results;
//Array of servo objects
Servo servo[6];
//Zero positions of servos, in this positions their arms are perfectly horizontal, in us
static int zero[6]={1475,1470,1490,1480,1460,1490};
//In this array is stored requested position for platform - x,y,z,rot(x),rot(y),rot(z)
static float arr[6]={0,0.0,0, radians(0),radians(0),radians(0)};
//Actual degree of rotation of all servo arms, they start at 0 - horizontal, used to reduce
//complexity of calculating new degree of rotation
static float theta_a[6]={0.0,0.0,0.0, 0.0,0.0,0.0};
//Array of current servo positions in us
static int servo_pos[6];
//rotation of servo arms in respect to axis x
const float beta[] = {pi/2,-pi/2,-pi/6, 5*pi/6,-5*pi/6,pi/6},
//maximum servo positions, 0 is horizontal position
      servo_min=radians(-80),servo_max=radians(80),
//servo_mult - multiplier used for conversion radians->servo pulse in us
//L1-effective length of servo arm, L2 - length of base and platform connecting arm
//z_home - height of platform above base, 0 is height of servo arms
servo_mult=400/(pi/4),L1 = 0.79,L2 = 4.66, z_home = 4.05;
//RD distance from center of platform to attachment points (arm attachment point)
//RD distance from center of base to center of servo rotation points (servo axis)
//theta_p-angle between two servo axis points, theta_r - between platform attachment points
//theta_angle-helper variable
//p[][]=x y values for servo rotation points
//re[]{}=x y z values of platform attachment points positions
//equations used for p and re will affect postion of X axis, they can be changed to achieve
//specific X axis position
const float RD = 2.42,PD =2.99,theta_p = radians(37.5),
theta_angle=(pi/3-theta_p)/2, theta_r = radians(8),
      p[2][6]={
            -PD*cos(deg30-theta_angle),-PD*cos(deg30-theta_angle),
            PD*sin(theta_angle),PD*cos(deg30+theta_angle),
            PD*cos(deg30+theta_angle),PD*sin(theta_angle)
            -PD*sin(deg30-theta_angle),PD*sin(deg30-theta_angle),
            PD*cos(theta_angle),PD*sin(deg30+theta_angle),
            -PD*sin(deg30+theta_angle),-PD*cos(theta_angle)
      re[3][6] = {
              -RD*sin(deg30+theta_r/2),-RD*sin(deg30+theta_r/2),
              -RD*sin(deg30-theta_r/2),RD*cos(theta_r/2),
              RD*cos(theta_r/2),-RD*sin(deg30-theta_r/2),
              -RD*cos(deg30+theta_r/2),RD*cos(deg30+theta_r/2),
              RD*cos(deg30-theta_r/2),RD*sin(theta_r/2),
              -RD*sin(theta_r/2),-RD*cos(deg30-theta_r/2),
              0,0,0,0,0,0
//arrays used for servo rotation calculation
//H[]-center position of platform can be moved with respect to base, this is
//translation vector representing this move
static float M[3][3], rxp[3][6], T[3], H[3] = {0,0,z_home};
void setup(){
//LCD inicialisation and turning on the backlight
#if LCD
   lcd.begin(16,2);
   lcd.setBacklightPin(BACKLIGHT_PIN, POSITIVE);
   lcd.setBacklight(HIGH);
   lcd.home();
#endif
//attachment of servos to PWM digital pins of arduino
   servo[0].attach(3, MIN, MAX);
   servo[1].attach(5, MIN, MAX);
   servo[2].attach(6, MIN, MAX);
   servo[3].attach(9, MIN, MAX);
   servo[4].attach(10, MIN, MAX);
   servo[5].attach(11, MIN, MAX);
//begin of serial communication
//putting into base position
   setPos(arr);
//function calculating needed servo rotation value
float getAlpha(int *i){
   static int n;
   static float th=0;
   static float q[3], dl[3], dl2;
   double min=servo_min;
   double max=servo_max;
   n=0;
   th=theta_a[*i];
   while(n<20){
    //calculation of position of base attachment point (point on servo arm where is leg connected)
      q[0] = L1*cos(th)*cos(beta[*i]) + p[0][*i];
      q[1] = L1*cos(th)*sin(beta[*i]) + p[1][*i];
      q[2] = L1*sin(th);
    //calculation of distance between according platform attachment point and base attachment point
      dl[0] = rxp[0][*i] - q[0];
      dl[1] = rxp[1][*i] - q[1];
      dl[2] = rxp[2][*i] - q[2];
      dl2 = sqrt(dl[0]*dl[0] + dl[1]*dl[1] + dl[2]*dl[2]);
    //if this distance is the same as leg length, value of theta_a is corrent, we return it
      if(abs(L2-dl2)<0.01){
         return th;
    //if not, we split the searched space in half, then try next value
      if(dl2<L2){
         max=th;
      }else{
         min=th;
      n+=1;
      if(max==servo_min || min==servo_max){
         return th;
      th = min+(max-min)/2;
   return th;
balance of the code from post above since I exceeded 9000 characters.
//function calculating rotation matrix
void getmatrix(float pe[])
   float psi=pe[5];
   float theta=pe[4];
   float phi=pe[3];
   M[0][0] = cos(psi)*cos(theta);
   M[1][0] = -sin(psi)*cos(phi)+cos(psi)*sin(theta)*sin(phi);
   M[2][0] = sin(psi)*sin(phi)+cos(psi)*cos(phi)*sin(theta);
   M[0][1] = sin(psi)*cos(theta);
   M[1][1] = cos(psi)*cos(phi)+sin(psi)*sin(theta)*sin(phi);
   M[2][1] = cos(theta)*sin(phi);
   M[0][2] = -sin(theta);
   M[1][2] = -cos(psi)*sin(phi)+sin(psi)*sin(theta)*cos(phi);
   M[2][2] = cos(theta)*cos(phi);
//calculates wanted position of platform attachment poins using calculated rotation matrix
//and translation vector
void getrxp(float pe[])
   for(int i=0;i<6;i++){
      rxp[0][i] = T[0]+M[0][0]*(re[0][i])+M[0][1]*(re[1][i])+M[0][2]*(re[2][i]);
      rxp[1][i] = T[1]+M[1][0]*(re[0][i])+M[1][1]*(re[1][i])+M[1][2]*(re[2][i]);
      rxp[2][i] = T[2]+M[2][0]*(re[0][i])+M[2][1]*(re[1][i])+M[2][2]*(re[2][i]);
//function calculating translation vector - desired move vector + home translation vector
void getT(float pe[])
   T[0] = pe[0]+H[0];
   T[1] = pe[1]+H[1];
   T[2] = pe[2]+H[2];
unsigned char setPos(float pe[]){
    unsigned char errorcount;
    errorcount=0;
    for(int i = 0; i < 6; i++)
        getT(pe);
        getmatrix(pe);
        getrxp(pe);
        theta_a[i]=getAlpha(&i);
        if(i==INV1||i==INV2||i==INV3){
            servo_pos[i] = constrain(zero[i] - (theta_a[i])*servo_mult, MIN,MAX);
        else{
            servo_pos[i] = constrain(zero[i] + (theta_a[i])*servo_mult, MIN,MAX);
        if(theta_a[i]==servo_min||theta_a[i]==servo_max||servo_pos[i]==MIN||servo_pos[i]==MAX){
            errorcount++;
        servo[i].writeMicroseconds(servo_pos[i]);
    return errorcount;
//functions used for displaying actual platform position on 16x2 LCD display
#if LCD
void showRot(){
   lcd.setCursor(0,0);
   lcd.print("Rot");
   lcd.setCursor(12,0);
   lcd.print((int)(arr[3]*deg2rad));
   lcd.setCursor(3,1);
   lcd.print((int)(arr[4]*deg2rad));
   lcd.setCursor(11,1);
   lcd.print((int)(arr[5]*deg2rad));
void showComm(){
   if(shown==0){
      shown=1;
      lcd.setCursor(3,0);
      lcd.print("ation x: ");
      lcd.setCursor(0,1);
      lcd.print("y: ");
      lcd.setCursor(8,1);
      lcd.print("z: ");
void clearNr(){
   lcd.print("    ");
   lcd.setCursor(3,1);
   lcd.print("     ");
   lcd.print("     ");
void showLoc(){
   lcd.setCursor(0,0);
   lcd.print("Loc");
   lcd.print((int)(arr[0]*25.4));
   lcd.setCursor(3,1);
   lcd.print((int)(arr[1]*25.4));
   lcd.print((int)(arr[2]*25.4));
#endif
//main control loop, obtain requested action from serial connection, then execute it
   if(Serial.available()>0){
      int input=Serial.read();
      switch(input){
//action to turn backlight off
         case SETBACKOFF:
#if LCD
            lcd.setBacklight(LOW);
#endif
//action to turn backlight on
         case SETBACKON:
#if LCD
#endif
//action to change position of platform, obtain 6 values representing desired position
         case SETPOSITIONS:
               long kk;
               while(Serial.available()<4){
               kk=(long)Serial.read();
               kk=kk+(Serial.read()<<8);
               kk=kk+(Serial.read()<<16);
               kk=kk+(Serial.read()<<24);
               if(i<3){
                  arr[i]=(kk/100)/25.4;
               }else{
                  arr[i]=radians(kk/100.0);
            Serial.write(setPos(arr));
            Serial.flush();
//enable of showing current position on LCD
         case PRINTPOS:
#if LCD
            showPos=PRINTPOS;
            time=millis();
#endif
//enable of controlling platformy by IrDA remote
        case SWITCHIRDA:
#if IrDA
            irrecv.enableIRIn();
            useIrda=SWITCHIRDA;
#endif
//reserved for future use - possiblity to send just servo timing values
//main control would be executed on communicating partner
         case SETPOSITIONSINMS:
               long kk;
               kk=kk|(Serial.read()<<8);
               kk=kk|(Serial.read()<<16);
               kk=kk|(Serial.read()<<24);
               servo[i].writeMicroseconds(kk);
//disable of showing current position on LCD
         case STOPPRINTPOS:
            showPos=STOPPRINTPOS;
            shown=0;
//disable of controlling platformy by IrDA remote
         case SWITCHIRDAOFF:
            useIrda=SWITCHIRDAOFF;
//return current position of platform
         case GEPOSITION:
            retPos();
         default:
//helping subroutine to print current position
#if LCD
   if(showPos==PRINTPOS){
      static byte act=0;
      showComm();
      if(millis()-time<1500){
         act=0;
      }else if(millis()-time<3000){
         if(act==0){
            act=1;
            clearNr();
            showRot();
      }else{
         time=millis();
         clearNr();
         showLoc();
#endif
//this part is used for IrDA position control
#if IrDA
   if(useIrda==SWITCHIRDA&&irrecv.decode(&results)){
      static byte val=0;
      switch(results.value){
         case MUTE_BUTTON:
            val=1;
         case STANDBY_ON:
            val=0;
         case VOL_UP:
            if(val<=2){
               arr[val]+=1;
            }else{
               arr[val]=radians((arr[val]*deg2rad)+0.4);
         case VOL_DOWN:
            if(val<=2){
               arr[val]-=1;
            }else{
               arr[val]=radians((arr[val]*deg2rad)-0.4);
         case DVD:
            val=2;
         case TV:
            val=3;
         case GAME:
            val=4;
         case CD:
            val=5;
      setPos(arr);
      irrecv.resume(); // Continue receiving
#endif
void retPos(){
       long val;
       if(i<3){
           val=(long)(arr[i]*100*25.4);
       }else{
           val=(long)(arr[i]*100*deg2rad);
       Serial.write(val);
       Serial.write((val>>8));
       Serial.write((val>>16));
       Serial.write((val>>24));
       Serial.flush();
