How to delete spaces after last letter from a string
I get a message like this in a string from my code.
string mess = ¨abcdef ¨;
In some other situation, the code gives me
string mess=¨abcd ¨;
the length of mess variable is always 16 .
I need to program with arduino code some way to delete all the spaces from mess after the last letter. How could I don that?
Thank you
(deleted)
See…
There is no need for this forum… Just Google.
Your string should be declared as:char mess[] = "abcdef          ";
Just replace the first space by a null character.
jbellavance:
That won't work if there are more letters beyond the first space.
Better to work backwards from the end of the string.
Would the trim() function do what you want ?
EDIT : just realised that C does not have such a function, which seems to be a strange omission
in code
void stripTrailingSpaces(char *s)
  int le = strlen(s) - 1;
  while (le >=0 && s[le] == ' ') le--;
  le++;
  s[le] = '\0';
some test strings
char test1 = "a a a a a aa aaaaaaaaaaaaaaaaaaaaa aaaaa aaa a a a a ";
char test2 = " ";
char test3 = "";
one could add a test to check if (s == NULL) return;
slightly faster
void stripTrailingSpaces1(char *s)
  int le = strlen(s);
  for (int i = le - 1; i >= 0; i--)
    if (s[i] == ' ') s[i] = '\0';
    else break;
As it is a String then you could use
int p = mess.indexOf(" ", 0);
if (p != -1) {
    partmess = mess.substring(0, p);
// will give issues if your original message contains spaces.!
or
mess.trim();
