How to detect a key press
The sketch you posted uses Serial.read() to get characters from the Serial Monitor, but the Serial Monitor will not send any characters until you press Return unless there is a trick that I am not aware of.
Unless there is such a trick then the sketch does not meet these requirements
There is. Press return. Otherwise use a pushbutton, like I did, to call the same function. I don't think the project in question is rocket surgery. Alternatively, change the 'x' to '\n'
@pinknami says that he/she want the Arduino to do something
not when a key followed by Return is pressed
Because of the requirement to react to one of many keys just pressing Return is not a solution, which is where I was leading when I asked
He/she did not reply when I asked
but taking the requirement literally (no use of Enter/Return) then it is not possible using the Serial Monitor but trivial using Coolterm
I still have my doubts that a PC needs to be involved at all but @pinknami has gone quiet
SUMMARY
We don't really know what @pinknami wants or needs and I suspect that neither does he/she
You've got that right: another satisfied customer :wink:
