How to detect "high" 3v3 signal on 5v Arduino ? - is analog input feasible ?
I am using an Atmega8 , (ArduinoNG)
It fails to regiver 3v3 logic.
I need only to "detect" a high state.
If I used analog input, how would that affect performace ? vs readdigital ?
does analog take more time ?
Yes, it does.
digitalRead() = 3 to 4 us
analogRead() = 100 to 130 us
Perhaps you can tweak the signal a little, with a diode or pullup resistor. But that depends on the device that is generating the 3.3V signal.
AndreK:
I need only to “detect” a high state.
According to the AtMega8 datasheet it should detect as high (assuming your powering it at 5V.
Anything below 0.2VCC should be low and above 0.6VCC high.
0.2 * 5.0 = 1V 0.6 * 5.0 = 3V
I have found no problem with an Uno (5v) detecting an input signal from 3v and 3.3v devices.
Obviously there is a risk of damage to the 3.3v device if you feed 5v to one of its input pins.
...R
Thanks everybody, I lowered the VCC for the Atmega8L to 4.6v , now it works fine :slight_smile:
