I have an 8" (20cm) irrigation pipe. The lid is secured with a threaded bolt through the center that screws into a bracket in the pipe. I need to detect leaks when the cap is not securely closed. The cap will be underwater and the water pressure can be upwards of 2 psi (25MPa).
I'm thinking a flow meter on the outside of the lid, but I need to detect leaks at any point on the seal.
I meant for the flow meters to be installed in the pipework not around the seal. This way you are monitoring the flow in the pipe out to the fields, both before and after the valve. If they don't match then the valve must be leaking.
DangerToMyself:
You missed the part where he said the lid will be under water.
I didn't say it would work for him, just that is what I use.
but, we are all just guessing. he has not given proper information.
a cap on a water pipe that is submerged.
what is the problem if it leaks ?
WHICH way is it leaking ?
what is the pressure ? 2 PSI or 3,500 PSI ? not that there is much difference.
how much of a leak.
how large is the surrounding tank ? say the lid is inside of a 10 gallon bucket and the water is leaking out of the seal. the water level in the bucket will rise. done deal.
what is the history of the leak ? if this has happened, once, in 1967, then who cares. if it happens hourly, then you need a new lid.
Ralph_S_Bacon:
got any sense of a flow meter for an 8 inch pipe that can resolve the difference of flows for a leak of a few GPH ?
