Im brand new to arduino and have an idea and would like some advise from the experts.
I would like to have a central arduino hooked up to a speaker. then have have other devices* connected via bluetooth/wifi** then once one of these devices go out of range have the arduino set the speaker off.
Now I'm not looking for a complete solution here I'm just looking for advise on what could be used to do what is needed.
*Which device can be used to send and receive signal (just a powered bluetooth module?, complete arduino set up or can any other device be used which can send signals?)
**The signal would be depended on the device used.
Here is an example scenario
The local animal shelter has 10 dogs. all of them have a transmitting device, transmitting a signal to the main arduino hooked up to a speaker at reception. The arduino knows to receive 10 signals at a given interval. If it only receives 9 signals (because a dog got out) it would set the alarm off.
How is the speaker powered? How is the Arduino supposed to turn it off or on?
If the bluetooth module is properly connected to the Arduino, and paired with something else, yes, it can be used. The key there is paired. The Arduino would be able to connect to exactly one other device.
That device would need to periodically send something to the Arduino to say "Hey, Jack, I'm still here..." (sometimes referred to as a heartbeat). The Arduino would note when it got the "Hey, Jack, I'm still here..." message. Periodically, (read that as "on every pass through loop()) the Arduino would compare now to then (when the last heartbeat happened) to decide whether to keep the session (speaker) alive or not.
Pretty much as I explained in the scenario. I need to have multiple devices send "heartbeats" to the main arduino. then if in a certain time I do not detect a "heartbeat" from one of the devices, I would want to send a signal to a speaker to sound a alarm.
for now sounding the alarm is not the main issue that I'm trying to solve. I just want to find out which devices I can use so that I can have 10+ send "heartbeats" to the main arduino.Must also be at a maximum of say 100m radius.
I would then check every other minute which dives haven't synced and if one is missing I will sound an alarm.
Dives? Within 100 meters of what?
Sounds to me like you need something like Series 2 XBees - one coordinator and any number of router/end devices. The end devices would periodically say "Here I am", and the coordinator would check off those that were accounted for.
I'm trying to find out if it is possible to do what I explained in my scenario.
Reason for this is livestock theft on my dads farm so as I have no experience arduino I would like to know if there can be a device that wont be too expensive and doesn't make use of GSM/GPRS as there is no cell reception.
These devices would need to be small enough to fit on a collar and speak to a main board.
were sheep #3 get stolen....I would want arduino to notice that #3 hasn't spoken to it in 5 minutes and sound the alarm.
I just want to know if my idea has some credibility behind it or not.
Yes, it is feasible. You have already received an answer about possible hardware (x-bees). You might also look into NRF2401+ with pre-amp and LNA for lower costs (and maybe loss of range).
Knowing that the sheep, or dog, or whatever it really is you are tracking, has been gone for five minutes is of about as much value as knowing it was gone yesterday.
You could increase the range of your net by using repeaters.
This sort of question comes up frequently, and there is no cheap or reliable unattended electronic solution. Batteries die, radio collars fall off, animals wander out of range, etc. Ranchers just have to live with loss of stock, at the very least from disease or injury.
