how to detect message when trip only once
hai…i have problem with that coding…i juz want detect a message when trip juz once…so now when trip, message when sent to me many time.it can waste my credit top up.so, how to fix that coding.tq
sim900.txt (4.56 KB)
  if (digitalRead(Trip == HIGH))It might be a good idea to fix this
yes..correct.but my project will turn to the LOW through sending text..that mean if i do if (digitalRead(Trip == HIGH)),i will get many time message from gsm because im implement pin trip to the RCCB..while RCCB trip i've got message,so i will send a message to the gsm to pull the RCCB fuse.as long as RCCB trip,the if (digitalRead(Trip == HIGH))..hope u can understand.
You should not be "doing" this.
use
 if (digitalRead(Trip) == HIGH)
same..not change
He didn't say it would fix your problem instantaneous, but it was at least a BIG error in your code. :wink:
hilmi91:
same..not change
Post the code as it is now in a new message
