How to detect rising or falling edge of a Pin Change Interrupt?
Hi.. I have this interrupt code that sets Pin Change interrupts on two PortB pins - PCINT9 (PB1) and PCINT10 (PB2) on an Attiny167.
It works, but what could I add to detect if the interrupt was flagged by a rising or falling edge?
volatile uint8_t portbhistory = 0xFF;  // default is high because of the  pull-ups
void initInterrupt() {
  PCICR |= 1 << PCIE1;                       // enable PCINT[8:15] pin change interrupt
  PCMSK1 |= (1 << PCINT9) | (1 << PCINT10);  // configure interrupt at PCINT9 PIN9 e PCINT10 PIN 10
  sei();                                     // globaly enable interrupts
ISR(PCINT1_vect) {
  uint8_t changedbits;
  changedbits = PINB ^ portbhistory;
  portbhistory = PINB;
  if (changedbits & (1 << PB1)) {  // PB1 is PCINT 9 - PCINT 9 changed
    trx2.tickISR();
  if (changedbits & (1 << PB2)) {  // PB2 is PCINT 10 - PCINT 10 changed
    disconnected_cable = 1;        // Cable is connected or disconnected ??
Could I just add this to check if PB2 was rising of falling?
// read PCINT10 (PB2 - pin 10):
  if(PINB & (1 << PB2)) {
    // rising edge detected
  else{
    // falling edge detected
So it would look like this? Is that correct?
ISR(PCINT1_vect) {
    trx2.tickISR();
    if (PINB & (1 << PB2)) {       // rising edge on PCINT10 detected
      disconnected_cable = 0;      // cable is connected
    } else {                       // falling edge on PCINT10 detected
      disconnected_cable = 1;      // Cable is disconnected
If the last edge was a falling edge, this one is rising. If the last one was rising, this one is falling.
... for when you realize you can't do it your way.
There's a library, if you're interested.
ISR(PCINT1_vect) {
  uint8_t changedbits, risingbits, fallingbits, portbnow;
  portbnow = PINB;
  changedbits = portbnow ^ portbhistory;
  risingbits = portbnow & ~portbhistory;
  fallingbits = ~portbnow & portbhistory;
  portbhistory = portbnow;
Read the pin in the interrupt routine.
If you have more than one pin doing inerrupts in a port you do need to determine which changed. then you can use the new value (HIGH or LOW) to determine if it was a RISING or FALLING interrupt this time.
I was going to suggest the same as last two posts. But actually, there is a caveat on that. It assumes that the signal remains stable long enough to read it, after the ISR is called.
Thanks! This interrupt is to detect if a cable is/has been plugged/unplugged...so it´s not a fast changing signal (on PB2) but ... if I´d like to detect two different interrupts on PortB, one on CHANGE, and the other on RISING and FALLING, it would be something like this, right? Is this correct?
volatile bool cable_connected = 0;
void setup(){
portbhistory = PINB;  // read PINB bits at power_up
initInterrupt();
  PCMSK1 |= 1 << PCINT9;   // configure interrupt at PCINT9 PIN9 - PB1
  PCMSK1 |= 1 << PCINT10;  // configure interrupt at PCINT10 PIN10 - PB2
ISR(PCINT1_vect) {
  portbnow = PINB;
  if (changedbits & (1 << PB1)) {  // PCINT 9 changed  - PB1
    // do something here
  if (fallingbits & (1 << PB2)) {  // Falling Edge on PCINT10 - PB2
    cable_connected = 1;           // Pin is Low, so cable is connected
  if (risingbits & (1 << PB2)) {   // Rising Edge on PCINT10 - PB2
    cable_connected = 0;           // Pin is High, so cable is disconnected
