I'm new to this and I'm trying to understand.
has Tinypico and has got a Bluetooth started to control the phone.
But I also try to get features like double click single click and long press button
attach the code. up and down arrow works but not the longclick function
does anyone see what I'm doing wrong
[[code]
#include "BleKeyboard.h"
#include "OneButton.h" //we need the OneButton library
#include <Keypad.h>
const byte ROWS = 4; //four rows
const byte COLS = 4; //four columns
char keys[ROWS][COLS] = {
{'1', '2', '3', 'A'},
{'4', '5', '6', 'B'},
{'7', '8', '9', 'C'},
{'*', '0', '#', 'D'},
byte rowPins[ROWS] = {23, 19, 18, 5}; //connect to the row pinouts of the keypad
byte colPins[COLS] = {22, 21, 32, 33 }; //connect to the column pinouts of the keypad
OneButton button('1', true);
BleKeyboard bleKeyboard;
Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS);
bleKeyboard.begin();
//button.attachDoubleClick(doubleclick); // link the function to be called on a doubleclick event.
//button.attachClick(singleclick); // link the function to be called on a singleclick event.
//button.attachLongPressStop(longclick); // link the function to be called on a longpress event.
void sendMacroCommand(uint8_t key) {
bleKeyboard.press(KEY_LEFT_CTRL);
bleKeyboard.press(KEY_LEFT_SHIFT);
bleKeyboard.press(KEY_LEFT_ALT);
bleKeyboard.press(key);
void longclick() {
Serial.println("Sending DOWN_ARROW key...");
bleKeyboard.write(KEY_DOWN_ARROW);
char key = keypad.getKey();
if (bleKeyboard.isConnected() && key) {
Serial.println(key);
switch (key) {
case '2':
Serial.println("Sending UP_ARROW key...");
bleKeyboard.write(KEY_UP_ARROW);
case '8':
The code, in loop, is not calling the longclick function.
If You read the topics like "How to use this Forum" You would:
Autoformat the code in the IDE. Then copy.
Use code tags according to the advice in 1)
It would come up like this:
#include <Keypad.h>
void longclick() {
switch (key) {
case '2':
case '8':
In the IDE, use the Edit tab and search. Search for "longclick". That function is not referred to, not called from any ware meaning it is never executed.
