I am using an encoder to tune a radio and want to tune by larger increments when the encoder turns quickly.
The tuning setup now is for each encoder detent the station increments by one, like this:
88.1, 88.3, 88.5, 88.7, 88.9, 89.1 etc. all the way to 107.9 and then it wraps around to 88.1
If the encoder is turning fast, it should increment in steps of 5 stations per detent like this:
88.1, 89.1, 90.1, 91.1, 92.1, etc all the way to 107.9 and then wrap around to 88.1
All I really need help with is setting a boolean variable named fastSwitch. An encoder speed greater than 200ms/detent should set it to the true state and when it slows down below 200ms/detent or stops, it should set it to the false state.
Once the is figured out, I can make the necessary tuning changes. I would prefer to do this without interrupts but if that's not possible or too complicated, it can use them.
