How to determine if ATMEGA328P is using internal or external clocks?
Can someone please shed some light on the subject? I very simply want to know how to check if my ATMEGA328P is using its internal or the external I have set up on pins 7 & 8 respectively.
Thanks in advance!
Read the fuses. The exact procedure will depend on the type of programmer you are using.
Read the low fuse with an isp programmer.
Or ground pin 7 while it's running and see if it stops :P
Run this sketch with and without the OSCCAL statement commented out. If you’re using the internal oscillator it will affect the blink rate.
#define LED_PIN 2        // LED and resistor between digital pin 2 and ground
  pinMode(LED_PIN, OUTPUT);
  OSCCAL = 0;
// 1 Hz blink
  digitalWrite(LED_PIN, HIGH);
  delay(100);
  digitalWrite(LED_PIN, LOW);
  delay(900);
DrAzzy:
Or ground pin 7 while it’s running and see if it stops.
Well, that was simple, wasn’t it?
