Hello guys,
I bought 3,5" TFT display from ebay. I'm using mcufriend library with arduinoMega.
It is possible turn on/off display or set brightness ? I can't find more info about that display.
And if I print something on display, background blinks. Know someone where there may be a problem ?
link on display>
More info about TFT >
19:50:26.436 -> Read Registers on MCUFRIEND UNO shield
19:50:26.469 -> controllers either read as single 16-bit
19:50:26.503 -> e.g. the ID is at readReg(0)
19:50:26.537 -> or as a sequence of 8-bit values
19:50:26.571 -> in special locations (first is dummy)
19:50:26.605 ->
19:50:26.605 -> reg(0x0000) 00 00 ID: ILI9320, ILI9325, ILI9335, ...
19:50:26.673 -> reg(0x0004) 00 54 80 66 Manufacturer ID
19:50:26.707 -> reg(0x0009) 00 00 61 00 00 Status Register
19:50:26.775 -> reg(0x000A) 00 08 Get Power Mode
19:50:26.809 -> reg(0x000C) 00 66 Get Pixel Format
19:50:26.843 -> reg(0x0061) 00 00 RDID1 HX8347-G
19:50:26.877 -> reg(0x0062) 00 00 RDID2 HX8347-G
19:50:26.911 -> reg(0x0063) 00 00 RDID3 HX8347-G
19:50:26.945 -> reg(0x0064) 00 00 RDID1 HX8347-A
19:50:26.979 -> reg(0x0065) 00 00 RDID2 HX8347-A
19:50:27.013 -> reg(0x0066) 00 00 RDID3 HX8347-A
19:50:27.047 -> reg(0x0067) 00 00 RDID Himax HX8347-A
19:50:27.081 -> reg(0x0070) 00 00 Panel Himax HX8347-A
19:50:27.149 -> reg(0x00A1) 00 93 30 93 30 RD_DDB SSD1963
19:50:27.183 -> reg(0x00B0) 00 00 RGB Interface Signal Control
19:50:27.251 -> reg(0x00B4) 00 00 Inversion Control
19:50:27.285 -> reg(0x00B6) 00 02 02 3B 3B Display Control
19:50:27.320 -> reg(0x00B7) 00 06 Entry Mode Set
19:50:27.353 -> reg(0x00BF) 00 00 00 00 00 00 ILI9481, HX8357-B
19:50:27.421 -> reg(0x00C0) 00 0E 0E 0E 0E 0E 0E 0E 0E Panel Control
19:50:27.466 -> reg(0x00C8) 00 00 00 00 00 00 00 00 00 00 00 00 00 GAMMA
19:50:27.500 -> reg(0x00CC) 00 04 Panel Control
19:50:27.534 -> reg(0x00D0) 00 00 00 Power Control
19:50:27.569 -> reg(0x00D2) 00 00 00 00 00 NVM Read
19:50:27.636 -> reg(0x00D3) 00 00 94 86 ILI9341, ILI9488
19:50:27.670 -> reg(0x00D4) 00 00 00 00 Novatek ID
19:50:27.704 -> reg(0x00DA) 00 54 RDID1
19:50:27.738 -> reg(0x00DB) 00 80 RDID2
19:50:27.772 -> reg(0x00DC) 00 66 RDID3
19:50:27.772 -> reg(0x00E0) 00 08 37 26 02 1C 02 71 49 5E 0F 1E 0D 1E 18 04 GAMMA-P
19:50:27.840 -> reg(0x00E1) 00 0A 3B 3E 09 0D 03 4E 95 4B 0E 0F 09 0E 1C 00 GAMMA-N
19:50:27.941 -> reg(0x00EF) 00 80 00 10 60 40 ILI9327
19:50:27.975 -> reg(0x00F2) 00 18 A3 12 02 B2 12 FF 10 00 00 00 Adjust Control 2
19:50:28.043 -> reg(0x00F6) 00 54 80 66 Interface Control
