How to disconnect nodeHandle
I've used :
while (nh.connected()) {...}
so my arduino car starts when ROSMASTER is running .
My problem is that i can't disconnect nodeHandle when i close the ROSMASTER , which is importan for my task . Any suggestions ???
OK, I give up. What is ROSMASTER ?
Please post a full sketch illustrating the problem, using code tags when you do
ROS MASTER is is the master in which ros nodes are publishing or subscribing to ros topics . The :
nh.connected()
is a function that checks if the ROS MASTER is running .
ROS = Robotic Operating System
Sorry, but that does not take us much further forward. All that I can glean from your reply is that
Your mention of publishing to topics makes it sound very like an MQTT system. Is that anything like you are describing ?
https://maker.pro/arduino/tutorial/how-to-use-arduino-with-robot-operating-system-ros <<< reads like MQTT.
