Every OneWire device has a distinct address. I'm quite sure you need it to read the values. As you hide the necessary code (= your complete sketch including links to used libraries) from us you have to find the relevant piece of code yourself.
See the code below.
I am familiar with 1-wire devices such as DS18b20 temperature sensors but this case seems a bit different because unless an RFID tag is brought close to a RFID reader, no device is found in the code. If a tag is detected by the reader, it is the tag address which is returned by the ds.search() function, not the reader’s address.
Cheers
Loic
#include <stdio.h>
#include <string.h>
#include <OneWire.h>
OneWire ds(A2);
byte addr[8];
String keyStatus="";
//Unique ID of known RFID tag
byte badge[6] = {205,30,189,0,3};
pinMode(2, OUTPUT);//Red LED
pinMode(3, OUTPUT);//Green LED
digitalWrite(2,HIGH);//Red LED Off
digitalWrite(3,HIGH);//Green LED Off
getKeyCode();
if(keyStatus=="ok")
byte i;
for( i = 5; i >0; i--) {
Serial.print(addr[i],HEX);
if(i>1) Serial.print(":");
Serial.print('\n');
if(CompareID(addr, badge))
digitalWrite(3,LOW);
digitalWrite(2,LOW);
Serial.print('\n');
else if (keyStatus!="") { Serial.print(keyStatus);}
bool CompareID(byte *Buff1, byte *Buff2)
bool Result = true;
byte i;
if(Buff1[i] != Buff2[i-1])
return false;
return true;
void getKeyCode(){
byte present = 0;
byte data[12];
keyStatus="";
if ( !ds.search(addr)) {
ds.reset_search();
return;
if ( OneWire::crc8( addr, 7) != addr[7]) {
keyStatus="CRC invalid";
return;
if ( addr[0] != 0x01) {
keyStatus="not DS1990A";
return;
keyStatus="ok";
ds.reset();
If a tag is detected by the reader, it is the tag address which is returned by the ds.search() function, not the reader's address.
That's quite special, this reader seems to emulare a DS1990 OneWire Serial Button using the RFID tags. As the reader is not addressable you cannot know which reader got a tag if you have multiple readers on the same bus. So if you need to know which reader has read a specific tag, use a separate bus for each reader.
pylon:
Indeed, and that is exactly how it is advertized. So the question could also apply to iButtons. Using separate buses for each reader would not be an issue in an Arduino project but in this case I am only using the Arduino to make a POC. The final implementation will be based on an industrial 1-Wire platform and I don't have several buses options on the platform.
Then you don't have the possibility to know which reader got the RFID tag.
Yes, but there you don't have a reader, you just have kind of a plug that makes the OneWire connection. You never know which plug was used if they all connect to the same bus.
