how to display 1 line from text File
what function I will use to grab only line1 from text file?
#include <SD.h>
#include <SPI.h>
File myFile;
  SD.begin();
  // re-open the file for reading:
  myFile = SD.open("test.txt");
  if (myFile) {
  //  Serial.println("test.txt:");
    // read from the file until there's nothing else in it:
    while (myFile.available()) {
    // Serial.write(myFile.read());
char lineOne[80]; // Assumes that a line contains no more than 79 characters
byte index = 0;
while(myFile.available() > 0)
   char nextChar = myFile.read();
   if(nextChar != '\n')
      lineOne[index++] = nextChar;
      lineOne[index] = '\0'; // Keep array NULL terminated
      //Serial.print("Line one: ");
       Serial.println(lineOne);
    // close the file:
    myFile.close();
    // if the file didn't open, print an error:
    Serial.println("error opening test.txt");
File::read(), called as many times as needed, until you get the still-undefined end of line marker. There is NO read-a-complete-line-and-i'm-not-going-to-define-exactly-what-that-means() method. YOU must write that functionality.
That code does something. You have NOT shown us what it does.
You expect that code to do something. You have NOT been anywhere near clear on what you expect it to do.
what's the actual question ?
What does your code do - especially this:
This causes the program to do just what the comment says. The program will read all of the lines, not just one.
groundFungus:
Except that there is a break statement in the while loop.
         byte index = 0;
         while (myFile.available() > 0)
            if (nextChar != '\n')
Doesn't that break from the second while, passing control back to the first while?
groundFungus:
        byte index = 0;
I missed that there were two while loops. There were not two of them when I wrote the snippet to read the first line, in another thread by the same poster.
