How to display a string value in Google Firebase?
I managed to display my ultrasonic sensor on the firebase
When it reaches a certain level, I need to display "HIGH", "LOW", and "MODERATE" like what I did before but on LCD.
I use this as my code in the firebase
if(r < 60.96){
   String s = "HIGH";
    delay(100);}
  if(r >60.96 && r<152.4){
   String s = "MODERATE";
    delay(100);}
  if(r >152.4){
   String s = "LOW";
    delay(100);}
 Firebase.setFloat(firebaseData, "Flood/cm", r);
 Firebase.setFloat(firebaseData, "/Flood/level", s);
 delay(200);
How can I display on the "level" in firebase the High, Moderate, and Low? Thankyou!
I'm not familiar with the firebase database.
But the functionsname Firebase.setFloat
says what it does
set a float-value.
So I guess the firebase-data-library has a similar function but with a different name that expresses "string"
You should always post your complete sketch. With just these few lines nobody knows if you are using an ESP or something different which have all different firebase-libraries
You should post code by using code-tags
There is an automatic function for doing this in the Arduino-IDE
just three steps
  1. press Ctrl-T for autoformatting your code
  2. do a rightclick with the mouse and choose "copy for forum"
  3. paste clipboard into write-window of a posting
best regards Stefan
Hello sir, here is the full code that i am using :slight_smile:
I just cant seem to include the string value to firebase but they said it supports string data
#include <WiFi.h>
#include <FirebaseESP32.h>
#include<UltraDistSensor.h>
//Ultrasonic Pins
int trigPin = 13;    // TRIG pin
int echoPin = 12;    // ECHO pin
float d, r, s;
//Earthquake perimeters
int xsample=0;
int ysample=0;
int zsample=0;
#define samples 50
int maxVal = 20;
int minVal = -20;
String H = "HIGH";
String M = "MOD ";
String L = "LOW ";
FirebaseData firebaseData;
//Firebase
#define FIREBASE_HOST "cloud-based-multialarm-default-rtdb.firebaseio.com"
#define FIREBASE_AUTH "sqJSyzl1QWPGTt3ujv0mE3gdGrZS6bnt6sPiy7ft"
//ESP8266
#define WIFI_SSID "Epis"
#define WIFI_PASSWORD "tp6bqCR2"
  WiFi.begin(WIFI_SSID, WIFI_PASSWORD);
  Serial.print("Attempting Connection");
  while(WiFi.status() !=WL_CONNECTED)
  {Serial.print("...");
    delay(500);}
    Serial.print("Connected Successfully");
    Serial.print(WiFi.localIP());
  Firebase.begin(FIREBASE_HOST, FIREBASE_AUTH);
  pinMode(trigPin, OUTPUT);
  pinMode(echoPin, INPUT);
  for(int i=0; i<samples;i++){
    xsample+=analogRead(25);
    ysample+=analogRead(26);
    zsample+=analogRead(27);
  xsample/=samples;
  ysample/=samples;
  zsample/=samples;
  //Flood
  digitalWrite(trigPin, LOW);
  delayMicroseconds(2);
  digitalWrite(trigPin, HIGH);
  delayMicroseconds(10);
  d = pulseIn(echoPin, HIGH);
  r = d*0.034/2;
  Serial.print(r);
  Serial.print(" cm");
  if (isnan(r)){
    Serial.print("error");
    return;
  if(r < 60.96){
   String s = "HIGH";
    delay(100);}
    delay(100);}
  if(r >152.4){
   String s = "LOW";
    delay(100);}
  int value1=analogRead(25);
  int value2=analogRead(26);
  int value3=analogRead(27);
  int xValue=xsample-value1;
  int yValue=ysample-value2;
  int zValue=zsample-value3;
 Firebase.setFloat(firebaseData, "/Earthquake/X", xValue);
 Firebase.setFloat(firebaseData, "/Earthquake/Y", yValue);
 Firebase.setFloat(firebaseData, "/Earthquake/Z", zValue);
 delay(200);
  //Earthquake
  Serial.print("x=");
  Serial.println(xValue);
  Serial.print("y=");
  Serial.println (yValue);
  Serial.print("z=");
  Serial.println(zValue);
  Serial.println("  ");
maybe this will assist:
https://firebase.google.com/docs/database/admin/retrieve-data
do you understand your variable xValue contains a comma-number which is a different dataTYPE than a string
and for variables that hold a comma-number which is dataTYPE "float" the command
setFloat is used
So a command
with your variable "s" which is dataTYPE String does not work
You have to find the command
which might be
setString
or
setStr
or something similar to handover variables of dataTYPE String
using setFloat for a variable of datatype String is like trying to drill a hole
with a toothbrush. Does not work.
For drilling a hole you need a drill.
For finding example-codes that demonstrate how to use strings do a google-search with this keywords
GitHub firebase "your word of interest"
best regards Stefan
thankyou sir! I used different way and got the data, I insert the setstring on my conditions like this
if(r < 60.96){
    Firebase.setString(firebaseData, "/Flood/level", "HIGH");
    delay(100);}
   Firebase.setString(firebaseData, "/Flood/level", "MODERATE");
    delay(100);}
  if(r >152.4){
   Firebase.setString(firebaseData, "/Flood/level", "LOW");
    delay(100);}
and it worked thankyou so much
glad I could help.
You wrote "thank you sir". To me using the word "sir" expresses a lot of respect.
Thank you very much for that. But I'm not working in the military-section or the police where "sir" is the common term. I'm just an Arduino-cc-user-forum-user. So a simple thank you is enough or if you think the help was really great a "thank you very much". The biggest thank you for me is if you contribute or help with anything anywhere anybody (not nescessarily in the forum).
The big circle of helping each other will close somewhere some day so that I will receive some help too.
best regards Stefan
