I'm making a college final project, namely esp32 cam qr code scanner but I found a problem that I can't bring up all strings in the split string method that I use, I assume that the library I use, namely "data->payload" is uin8_t and not can be converted to string, is there any solution? Sorry, I'm very new to this kind of stuff.
And this is the code
ESP32-CAM QR code Reader
Author : ChungYi Fu (Kaohsiung, Taiwan) 2021-8-13 20:00
https://www.facebook.com/francefu
Refer to the code
https://github.com/alvarowolfx/ESP32QRCodeReader
自訂指令格式 http://192.168.xxx.xxx/control?cmd=P1;P2;P3;P4;P5;P6;P7;P8;P9
http://192.168.xxx.xxx/?ip //取得APIP, STAIP
http://192.168.xxx.xxx/?mac //取得MAC位址
http://192.168.xxx.xxx/?digitalwrite=pin;value //數位輸出
http://192.168.xxx.xxx/?analogwrite=pin;value //類比輸出
http://192.168.xxx.xxx/?digitalread=pin //數位讀取
http://192.168.xxx.xxx/?analogread=pin //類比讀取
http://192.168.xxx.xxx/?touchread=pin //觸碰讀取
http://192.168.xxx.xxx/?restart //重啟電源
http://192.168.xxx.xxx/?flash=value //閃光燈 value= 0~255
http://192.168.xxx.xxx/?servo=pin;value //伺服馬達 value= 0~180
http://192.168.xxx.xxx/?relay=pin;value //繼電器 value = 0, 1
http://192.168.xxx.xxx/?uart=value //序列埠
//輸入WIFI連線帳號密碼
const char* ssid = "IPAN";
const char* password = "Inpres11";
//輸入AP端連線帳號密碼 http://192.168.4.1
const char* apssid = "";
const char* appassword = ""; //AP密碼至少要8個字元以上
String Feedback = ""; //回傳客戶端訊息
//指令參數值
String Command = "", cmd = "", P1 = "", P2 = "", P3 = "", P4 = "", P5 = "", P6 = "", P7 = "", P8 = "", P9 = "";
//指令拆解狀態值
byte ReceiveState = 0, cmdState = 1, strState = 1, questionstate = 0, equalstate = 0, semicolonstate = 0;
#include <WiFi.h>
#include "esp_camera.h" //視訊函式
#include "soc/soc.h" //用於電源不穩不重開機
#include "soc/rtc_cntl_reg.h" //用於電源不穩不重開機
#include "quirc.h"
TaskHandle_t Task;
//ESP32-CAM 安信可模組腳位設定
#define PWDN_GPIO_NUM 32
#define RESET_GPIO_NUM -1
#define XCLK_GPIO_NUM 0
#define SIOD_GPIO_NUM 26
#define SIOC_GPIO_NUM 27
#define Y9_GPIO_NUM 35
#define Y8_GPIO_NUM 34
#define Y7_GPIO_NUM 39
#define Y6_GPIO_NUM 36
#define Y5_GPIO_NUM 21
#define Y4_GPIO_NUM 19
#define Y3_GPIO_NUM 18
#define Y2_GPIO_NUM 5
#define VSYNC_GPIO_NUM 25
#define HREF_GPIO_NUM 23
#define PCLK_GPIO_NUM 22
struct QRCodeData
bool valid;
int dataType;
uint8_t payload[1024];
int payloadLen;
String getValue(String data, char separator, int index)
int found = 0;
int strIndex[] = {0, -1};
int maxIndex = data.length()-1;
for(int i=0; i<=maxIndex && found<=index; i++){
if(data.charAt(i)==separator || i==maxIndex){
found++;
strIndex[0] = strIndex[1]+1;
strIndex[1] = (i == maxIndex) ? i+1 : i;
return found>index ? data.substring(strIndex[0], strIndex[1]) : "";
struct quirc *q = NULL;
uint8_t *image = NULL;
camera_fb_t * fb = NULL;
struct quirc_code code;
struct quirc_data data;
quirc_decode_error_t err;
struct QRCodeData qrCodeData;
String QRCodeResult = "";
WiFiServer server(80);
WiFiClient client;
camera_config_t config;
WRITE_PERI_REG(RTC_CNTL_BROWN_OUT_REG, 0); //關閉電源不穩就重開機的設定
Serial.setDebugOutput(true); //開啟診斷輸出
//視訊組態設定 https://github.com/espressif/esp32-camera/blob/master/driver/include/esp_camera.h
config.ledc_channel = LEDC_CHANNEL_0;
config.ledc_timer = LEDC_TIMER_0;
config.pin_d0 = Y2_GPIO_NUM;
config.pin_d1 = Y3_GPIO_NUM;
config.pin_d2 = Y4_GPIO_NUM;
config.pin_d3 = Y5_GPIO_NUM;
config.pin_d4 = Y6_GPIO_NUM;
config.pin_d5 = Y7_GPIO_NUM;
config.pin_d6 = Y8_GPIO_NUM;
config.pin_d7 = Y9_GPIO_NUM;
config.pin_xclk = XCLK_GPIO_NUM;
config.pin_pclk = PCLK_GPIO_NUM;
config.pin_vsync = VSYNC_GPIO_NUM;
config.pin_href = HREF_GPIO_NUM;
config.pin_sscb_sda = SIOD_GPIO_NUM;
config.pin_sscb_scl = SIOC_GPIO_NUM;
config.pin_pwdn = PWDN_GPIO_NUM;
config.pin_reset = RESET_GPIO_NUM;
config.xclk_freq_hz = 10000000;
config.pixel_format = PIXFORMAT_GRAYSCALE;
config.frame_size = FRAMESIZE_QVGA;
config.jpeg_quality = 15;
config.fb_count = 1;
//視訊初始化
esp_err_t err = esp_camera_init(&config);
if (err != ESP_OK) {
Serial.printf("Camera init failed with error 0x%x", err);
ESP.restart();
sensor_t * s = esp_camera_sensor_get();
s->set_framesize(s, FRAMESIZE_QVGA);
//s->set_vflip(s, 1); //垂直翻轉
//s->set_hmirror(s, 1); //水平鏡像
//閃光燈(GPIO4)
ledcAttachPin(4, 4);
ledcSetup(4, 5000, 8);
WiFi.mode(WIFI_AP_STA); //其他模式 WiFi.mode(WIFI_AP); WiFi.mode(WIFI_STA);
//指定Client端靜態IP
//WiFi.config(IPAddress(192, 168, 201, 100), IPAddress(192, 168, 201, 2), IPAddress(255, 255, 255, 0));
for (int i = 0; i < 2; i++) {
WiFi.begin(ssid, password); //執行網路連線
Serial.println("");
Serial.print("Connecting to ");
Serial.println(ssid);
long int StartTime = millis();
if ((StartTime + 5000) < millis()) break; //等待10秒連線
if (WiFi.status() == WL_CONNECTED) { //若連線成功
WiFi.softAP((WiFi.localIP().toString() + "_" + (String)apssid).c_str(), appassword); //設定SSID顯示客戶端IP
Serial.println("");
Serial.println("STAIP address: ");
Serial.println("");
for (int i = 0; i < 5; i++) { //若連上WIFI設定閃光燈快速閃爍
ledcWrite(4, 10);
delay(200);
ledcWrite(4, 0);
delay(200);
if (WiFi.status() != WL_CONNECTED) { //若連線失敗
WiFi.softAP((WiFi.softAPIP().toString() + "_" + (String)apssid).c_str(), appassword);
for (int i = 0; i < 2; i++) { //若連不上WIFI設定閃光燈慢速閃爍
ledcWrite(4, 10);
ledcWrite(4, 0);
//指定AP端IP
//WiFi.softAPConfig(IPAddress(192, 168, 4, 1), IPAddress(192, 168, 4, 1), IPAddress(255, 255, 255, 0));
Serial.println("");
Serial.println("APIP address: ");
Serial.println(WiFi.softAPIP());
Serial.println("");
//設定閃光燈為低電位
pinMode(4, OUTPUT);
digitalWrite(4, LOW);
server.begin();
xTaskCreatePinnedToCore(
QRCodeReader, /* Task function. */
"Task", /* name of task. */
10000, /* Stack size of task */
NULL, /* parameter of the task */
1, /* priority of the task */
&Task, /* Task handle to keep track of created task */
0); /* pin task to core 0 */
Serial.print("listenConnection running on core ");
Serial.println(xPortGetCoreID());
listenConnection();
void QRCodeReader( void * pvParameters ) {
Serial.print("QRCodeReader running on core ");
while (1) {
q = quirc_new();
if (q == NULL) {
Serial.print("can't create quirc object\r\n");
continue;
fb = esp_camera_fb_get();
if (!fb)
Serial.println("Camera capture failed");
continue;
//Serial.printf("quirc_begin\r\n");
quirc_resize(q, fb->width, fb->height);
image = quirc_begin(q, NULL, NULL);
//Serial.printf("Frame w h len: %d, %d, %d \r\n", fb->width, fb->height, fb->len);
memcpy(image, fb->buf, fb->len);
quirc_end(q);
//Serial.printf("quirc_end\r\n");
int count = quirc_count(q);
if (count > 0) {
Serial.println(count);
quirc_extract(q, 0, &code);
err = quirc_decode(&code, &data);
if (err) {
Serial.println("Decoding FAILED");
QRCodeResult = "Decoding FAILED";
Serial.printf("Decoding successful:\n");
dumpData(&data);
qrCodeData.dataType = data.data_type;
for (int j = 0; j < data.payload_len; j++)
qrCodeData.payload[j] = data.payload[j];
qrCodeData.valid = true;
qrCodeData.payload[data.payload_len] = '\0';
qrCodeData.payloadLen = data.payload_len;
//vTaskDelay(3000/portTICK_RATE_MS);
esp_camera_fb_return(fb);
fb = NULL;
image = NULL;
quirc_destroy(q);
void dumpData(const struct quirc_data *data)
Serial.printf("Version: %d\n", data->version);
Serial.printf("ECC level: %c\n", "MLHQ"[data->ecc_level]);
Serial.printf("Mask: %d\n", data->mask);
Serial.printf("Length: %d\n", data->payload_len);
Serial.printf("Payload: %s\n", data->payload);
const unsigned char* str =data->payload;
const char tokens = *str;
// String testtok= String(tokens);
String stringku =String (tokens);
Serial.print("data string: "); Serial.println(stringku);
String substringku0 = getValue(stringku, ' ', 0);
Serial.print("substring[0]: "); Serial.println(substringku0);
String substringku3 = getValue(stringku, ' ', 3);
Serial.print("substring[3]: "); Serial.println(substringku3);
Serial.print(*str);
// uint8_t token_idx = 0;
QRCodeResult = (const char *)data->payload;
//執行自訂指令
void ExecuteCommand() {
//Serial.println("");
//Serial.println("Command: "+Command);
if (cmd != "getstill") {
Serial.println("cmd= " + cmd + " ,P1= " + P1 + " ,P2= " + P2 + " ,P3= " + P3 + " ,P4= " + P4 + " ,P5= " + P5 + " ,P6= " + P6 + " ,P7= " + P7 + " ,P8= " + P8 + " ,P9= " + P9);
Serial.println("");
//自訂指令區塊 http://192.168.xxx.xxx?cmd=P1;P2;P3;P4;P5;P6;P7;P8;P9
if (cmd == "your cmd") {
// You can do anything
// Feedback="<font color=\"red\">Hello World</font>"; //可為一般文字或HTML語法
else if (cmd == "ip") { //查詢APIP, STAIP
Feedback = "AP IP: " + WiFi.softAPIP().toString();
Feedback += "<br>";
Feedback += "STA IP: " + WiFi.localIP().toString();
else if (cmd == "mac") { //查詢MAC位址
Feedback = "STA MAC: " + WiFi.macAddress();
else if (cmd == "restart") { //重設WIFI連線
ESP.restart();
else if (cmd == "digitalwrite") { //數位輸出
ledcDetachPin(P1.toInt());
pinMode(P1.toInt(), OUTPUT);
digitalWrite(P1.toInt(), P2.toInt());
else if (cmd == "digitalread") { //數位輸入
Feedback = String(digitalRead(P1.toInt()));
else if (cmd == "analogwrite") { //類比輸出
if (P1 == "4") {
ledcWrite(4, P2.toInt());
else {
ledcAttachPin(P1.toInt(), 9);
ledcSetup(9, 5000, 8);
ledcWrite(9, P2.toInt());
else if (cmd == "analogread") { //類比讀取
Feedback = String(analogRead(P1.toInt()));
else if (cmd == "touchread") { //觸碰讀取
Feedback = String(touchRead(P1.toInt()));
else if (cmd == "framesize") { //解析度
int val = P1.toInt();
s->set_framesize(s, (framesize_t)val);
else if (cmd == "quality") { //畫質
s->set_quality(s, val);
else if (cmd == "contrast") { //對比
s->set_contrast(s, val);
else if (cmd == "brightness") { //亮度
s->set_brightness(s, val);
else if (cmd == "hmirror") { //水平鏡像
s->set_hmirror(s, val);
else if (cmd == "vflip") { //垂直翻轉
s->set_vflip(s, val);
else if (cmd == "serial") { //序列埠
Serial.print(P1);
else if (cmd == "restart") { //重啟電源
ESP.restart();
else if (cmd == "flash") { //閃光燈
ledcWrite(4, val);
else if (cmd == "servo") { //伺服馬達 (0-180)
ledcAttachPin(P1.toInt(), 3);
ledcSetup(3, 50, 16);
int val = 7864 - P2.toInt() * 34.59;
if (val > 7864)
val = 7864;
else if (val < 1638)
val = 1638;
ledcWrite(3, val);
else if (cmd == "relay") { //繼電器
digitalWrite(13, P2.toInt());
else {
Feedback = "Command is not defined.";
if (Feedback == "") Feedback = Command;
//自訂網頁首頁管理介面
static const char PROGMEM INDEX_HTML[] = R"rawliteral(
<!DOCTYPE html>
<head>
<title></title>
<meta charset="utf-8">
<meta name="viewport" content="width=device-width, initial-scale=1">
</head>
<body>
<canvas id="canvas" width="320" height="240"></canvas><br>
Flash<input type="range" id="flash" min="0" max="255" value="0">
<input type="button" value="Get Still" onclick="getStill();"><br>
<div id="result" style="color:red"></div>
</body>
</html>
<script>
var canvas = document.getElementById('canvas');
var context = canvas.getContext('2d');
var flash = document.getElementById('flash');
var result = document.getElementById('result');
flash.onchange = function() {
var query = document.location.origin+"/?flash="+flash.value;
fetch(query);
function getStill() {
var xhr = new XMLHttpRequest();
xhr.open("GET", "/?getstill", true);
xhr.responseType = "arraybuffer";
xhr.onload = function (oEvent) {
var arrayBuffer = xhr.response; // Note: not xhr.responseText
if (arrayBuffer) {
var byteArray = new Uint8Array(arrayBuffer);
var imgData=context.getImageData(0,0,canvas.width,canvas.height);
var val = 0;
for (var i=0;i<imgData.data.length;i+=4) {
val = parseInt(byteArray[i/4], 10);
imgData.data[i]=val;
imgData.data[i+1]=val;
imgData.data[i+2]=val;
imgData.data[i+3]=255;
context.putImageData(imgData,0,0);
setTimeout(function(){getStill();}, 100);
xhr.send(null);
</script>
)rawliteral";
void listenConnection() {
Feedback="";Command="";cmd="";P1="";P2="";P3="";P4="";P5="";P6="";P7="";P8="";P9="";
ReceiveState=0,cmdState=1,strState=1,questionstate=0,equalstate=0,semicolonstate=0;
client = server.available();
if (client) {
String currentLine = "";
while (client.connected()) {
if (client.available()) {
char c = client.read();
getCommand(c); //將緩衝區取得的字元拆解出指令參數
if (c == '\n') {
if (currentLine.length() == 0) {
if (cmd=="getstill") {
getStill();
mainPage();
Feedback="";
currentLine = "";
} else if (c != '\r') {
currentLine += c;
if ((currentLine.indexOf("?")!=-1)&&(currentLine.indexOf(" HTTP")!=-1)) {
if (Command.indexOf("stop")!=-1) { //若指令中含關鍵字stop立即斷線 -> http://192.168.xxx.xxx?cmd=aaa;bbb;ccc;stop
client.println();
client.println();
client.stop();
currentLine="";
Feedback="";
ExecuteCommand();
delay(1);
client.stop();
void mainPage() {
//回傳HTML首頁或Feedback
client.println("Access-Control-Allow-Headers: Origin, X-Requested-With, Content-Type, Accept");
client.println("Access-Control-Allow-Methods: GET,POST,PUT,DELETE,OPTIONS");
client.println("Content-Type: text/html; charset=utf-8");
client.println("Access-Control-Allow-Origin: *");
client.println("Connection: close");
client.println();
String Data="";
if (cmd!="")
Data = Feedback;
else {
Data = String((const char *)INDEX_HTML);
int Index;
for (Index = 0; Index < Data.length(); Index = Index+1024) {
client.print(Data.substring(Index, Index+1024));
void getStill() {
if(!fb) {
return;
uint8_t *fbBuf = fb->buf;
size_t fbLen = fb->len;
client.println("Content-Type: application/octet-stream");
client.println();
for (size_t n=0;n<fbLen;n=n+1024) {
if (n+1024<fbLen) {
client.write(fbBuf, 1024);
fbBuf += 1024;
else if (fbLen%1024>0) {
size_t remainder = fbLen%1024;
client.write(fbBuf, remainder);
pinMode(4, OUTPUT);
//拆解命令字串置入變數
void getCommand(char c) {
if (c=='?') ReceiveState=1;
if ((c==' ')||(c=='\r')||(c=='\n')) ReceiveState=0;
if (ReceiveState==1)
Command=Command+String(c);
if (c=='=') cmdState=0;
if (c==';') strState++;
if ((cmdState==1)&&((c!='?')||(questionstate==1))) cmd=cmd+String(c);
if ((cmdState==0)&&(strState==1)&&((c!='=')||(equalstate==1))) P1=P1+String(c);
if ((cmdState==0)&&(strState==2)&&(c!=';')) P2=P2+String(c);
if ((cmdState==0)&&(strState==3)&&(c!=';')) P3=P3+String(c);
if ((cmdState==0)&&(strState==4)&&(c!=';')) P4=P4+String(c);
if ((cmdState==0)&&(strState==5)&&(c!=';')) P5=P5+String(c);
if ((cmdState==0)&&(strState==6)&&(c!=';')) P6=P6+String(c);
if ((cmdState==0)&&(strState==7)&&(c!=';')) P7=P7+String(c);
if ((cmdState==0)&&(strState==8)&&(c!=';')) P8=P8+String(c);
if ((cmdState==0)&&(strState>=9)&&((c!=';')||(semicolonstate==1))) P9=P9+String(c);
if (c=='?') questionstate=1;
if (c=='=') equalstate=1;
if ((strState>=9)&&(c==';')) semicolonstate=1;
the main problem is in void dumpData(const struct quirc_data *data) And the output like this
