how to display all lcd values to serial terminal
dear experts i just want to display kwhr and its value in serial terminal here is the code pls help me
#include <LiquidCrystal.h>
LiquidCrystal lcd(3, 5, 6, 7, 8, 9);
const int voltageSensor = A0;
const int currentSensor = A1;
const int numberOfSamples = 3000;
// Calibration constants
const float AC_WALL_VOLTAGE = 120.9;
const float AC_ADAPTER_VOLTAGE = 14.1;
const float AC_VOLTAGE_DIV_VOUT = 0.85;
const float CT_BURDEN_RESISTOR = 40.2;
const float CT_TURNS = 2280.0;
// Calibration coefficients
const float VCAL = 1.0;
const float ICAL = 1.0;
const float PHASECAL = 0.9;
// Calculated ratio constants, modified by VCAL/ICAL
const float AC_ADAPTER_RATIO = AC_WALL_VOLTAGE / AC_ADAPTER_VOLTAGE;
const float AC_VOLTAGE_DIV_RATIO = AC_ADAPTER_VOLTAGE / AC_VOLTAGE_DIV_VOUT;
const float V_RATIO = AC_ADAPTER_RATIO * AC_VOLTAGE_DIV_RATIO * 5 / 1024 * VCAL;
const float I_RATIO = CT_TURNS / CT_BURDEN_RESISTOR * 5 / 1024 * ICAL;
// Sample variables
int lastSampleV, lastSampleI, sampleV, sampleI;
// Filter variables
float lastFilteredV, lastFilteredI, filteredV, filteredI;
// Power sample totals
float sumI, sumV, sumP;
// Phase calibrated instantaneous voltage
float calibratedV;
// Calculated power variables
float realPower, apparentPower, powerFactor, voltageRMS, currentRMS;
unsigned long last_kWhTime, kWhTime;
float kilowattHour = 0.0;
lcd.begin(16,2);
calculatePower();
displayPower();
void calculatePower() {
for (int i = 0; i < numberOfSamples; i++) {
// Used for voltage offset removal
lastSampleV = sampleV;
lastSampleI = sampleI;
// Read voltage and current values
sampleV = analogRead(voltageSensor);
sampleI = analogRead(currentSensor);
lastFilteredV = filteredV;
lastFilteredI = filteredI;
// Digital high pass filters to remove 2.5V DC offset
filteredV = 0.996 * (lastFilteredV + sampleV - lastSampleV);
filteredI = 0.996 * (lastFilteredI + sampleI - lastSampleI);
// Phase calibration
calibratedV = lastFilteredV + PHASECAL * (filteredV - lastFilteredV);
// Root-mean-square voltage
sumV += calibratedV * calibratedV;
// Root-mean-square current
sumI += filteredI * filteredI;
// Instantaneous Power
sumP += abs(calibratedV * filteredI);
// Calculation of the root of the mean of the voltage and current squared (rms)
// Calibration coeficients applied
voltageRMS = V_RATIO * sqrt(sumV / numberOfSamples);
currentRMS = I_RATIO * sqrt(sumI / numberOfSamples);
// Calculate power values
realPower = V_RATIO * I_RATIO * sumP / numberOfSamples;
apparentPower = voltageRMS * currentRMS;
powerFactor = realPower / apparentPower;
// Calculate running total kilowatt hours
// This value will reset in 50 days
last_kWhTime = kWhTime;
kWhTime = millis();
// Convert watts into kilowatts and multiply by the time since the last reading in ms
kilowattHour += (realPower / 1000) * ((kWhTime - last_kWhTime) / 3600000.0);
// Reset sample totals
sumV = 0;
sumI = 0;
sumP = 0;
void displayPower() {
lcd.clear();
lcd.print(realPower, 0);
lcd.print("w ");
lcd.print(apparentPower, 0);
lcd.print("va ");
lcd.print(powerFactor * 100, 0);
lcd.print("%");
lcd.setCursor(0,1);
lcd.print(voltageRMS, 0);
lcd.print("v ");
lcd.print(currentRMS, 1);
lcd.print("a ");
lcd.print(kilowattHour, 4);
how???
Did you read points 6 and 7 of Read this before posting a programming question ...?
Come back if you have further questions.
It's funny how you can figure out to use lcd.begin() and lcd.print(), but you can't figure out how to use Serial.begin() and Serial.print().
One would almost get the impression that you haven't even tried.
