How to display (count) in serial monitor as Seconds instead of miliseconds
This is my code for a school project but i want to change the displayed Miliseconds to seconds
instead of showing (Your reaction speed is 325 ms) , i want it to show (Your reaction speed is 3.25 seconds)
int red = 5;
int yellow = 4;
int green = 3;
int button = 8;
long randno;
// Assign names to the port
  Serial.begin(9600);  //enabling serial communication
  // set initial LED state
  pinMode(red,OUTPUT);
  pinMode(yellow,OUTPUT);
  pinMode(green,OUTPUT);
  pinMode(button,INPUT_PULLUP);
  Serial.println("WELCOME TO REACTION TIMER"); // Display in serial monitor on start-up
   unsigned long count = 0;
   unsigned long butthold = 0;
   char buttvalue;
   randno = random(1000,5000);  //function to random a time from 1Sec - 5Sec
   digitalWrite(green,HIGH);  //Light up Green
   delay(randno);   // use the command declared on top, random a time from 1Sec - 5Sec
   digitalWrite(red,HIGH);  //after a random time, light up red
   digitalWrite(green,LOW); //off green
  do
    butthold++; //increment of button pressed
    buttvalue = digitalRead(button);  //read value of button
  while(buttvalue == LOW);  //if button is pressed
  do
    buttvalue = digitalRead(button);  // read value of pin 8 and assign to button
    delay(1); //ensure the loop takes 1 Miliseconds
    count++;  //increase counter by 1
   while(buttvalue == HIGH); //if button is not pressed
   if(butthold > 1) //if button is pressed more than once before light change
     Serial.println("HEY DONT CHEAT! Restarting....Rdy?"); //print dont cheat
     digitalWrite(red,LOW); //and red led remains on
   else //if everything is fine and button is pressed
    digitalWrite(red,LOW);  //off red led
    digitalWrite(yellow,HIGH);  //on yellow led
    Serial.print("Your reaction speed is: ");   //display text into serial monitor
    Serial.print(count);  //display the counted timing
    Serial.println(" MiliSeconds");   //display text into serial monitor
    delay(2000);  // after displaying, delay 2 Sec
    Serial.println("Next round is starting....Get Ready");   //display text into serial monitor
    digitalWrite(yellow,LOW);
   } // after this end this loop and go back to the start of loop
325 milliseconds is 0.325 seconds.
Better work on that arithmetic a bit more.
@wenhannn
Duplicate DELETED.
DO NOT CROSS POST !
Please READ THIS POST to help you get the best out of the forum,
Bob.
