How to display image on TTGO-T-Display ESP32
I used the sample code of Jpegcoder and An error keep occur:
Arduino: 1.8.19 (Windows 10), Board: "LilyGo T-Display, Disabled, Core 1, Core 1, Default 4MB with spiffs (1.2MB APP/1.5MB SPIFFS), 240MHz (WiFi/BT), QIO, 80MHz, 4MB (32Mb), 921600, None, Disabled"
Sketch uses 353105 bytes (26%) of program storage space. Maximum is 1310720 bytes.
Global variables use 24488 bytes (7%) of dynamic memory, leaving 303192 bytes for local variables. Maximum is 327680 bytes.
usage: esptool [-h]
           [--chip {auto,esp8266,esp32,esp32s2,esp32s3beta2,esp32s3,esp32c3,esp32c6beta,esp32h2beta1,esp32h2beta2,esp32c2,esp32c6,esp32h2}]
           [--port PORT] [--baud BAUD]
           [--before {default_reset,usb_reset,no_reset,no_reset_no_sync}]
           [--after {hard_reset,soft_reset,no_reset,no_reset_stub}]
           [--no-stub] [--trace] [--override-vddsdio [{1.8V,1.9V,OFF}]]
           [--connect-attempts CONNECT_ATTEMPTS]
           {load_ram,dump_mem,read_mem,write_mem,write_flash,run,image_info,make_image,elf2image,read_mac,chip_id,flash_id,read_flash_status,write_flash_status,read_flash,verify_flash,erase_flash,erase_region,merge_bin,get_security_info,version}
esptool: error: argument operation: invalid choice: '{upload.flags}' (choose from 'load_ram', 'dump_mem', 'read_mem', 'write_mem', 'write_flash', 'run', 'image_info', 'make_image', 'elf2image', 'read_mac', 'chip_id', 'flash_id', 'read_flash_status', 'write_flash_status', 'read_flash', 'verify_flash', 'erase_flash', 'erase_region', 'merge_bin', 'get_security_info', 'version')
I had the same error. There were two lines missing in .arduino15/packages/esp32/hardware/esp32/2.0.14/boards.txt:
lilygo_t_display.upload.flags=
lilygo_t_display.upload.extra_flags=
Lines added, IDE restarted, uploading worked...
Is it a TTGO T-Display S3?
when yes, go to their GITHUB:
GitHub - Xinyuan-LilyGO/T-Display-S3
download and install the
TFT_eSPI
start with the Sketch
T-Display-S3/example/tft at main · Xinyuan-LilyGO/T-Display-S3 · GitHub
should work right of the box. Includes an example to display an image.
its just ttgo t-display
I cant upload an image, when I check the serial terminal, it appear this error:
E (599) esp_littlefs: ./components/esp_littlefs/src/littlefs/lfs.c:1347:error: Corrupted dir pair at {0x0, 0x1}
E (599) esp_littlefs: mount failed, (-84)
E (600) esp_littlefs: Failed to initialize LittleFS
SPIFFS initialisation failed!
This resolved uploads for me using the T-Display template. Previously I was just using ESP32 Dev Board without issue, but had to manually set everything.
You just made my day, thanks!
you're a lifesaver! this worked
