Hello,
Beginner question, I am was using Paul Stoffregen Encoder library to use 2 rotary encoders. I hooked everything up and it works but the value increases by 4 every time I rotate the encoder but I want it to increase it by just 1 instead. How would I go about doing this?
Here is the code,
#include <Encoder.h>
// Change these pin numbers to the pins connected to your encoder.
// Best Performance: both pins have interrupt capability
// Good Performance: only the first pin has interrupt capability
// Low Performance: neither pin has interrupt capability
Encoder knobLeft(2, 6);
Encoder knobRight(3, 4);
long newLeft = 0;
long newRight = 0;
Serial.println("TwoKnobs Encoder Test:");
long positionLeft = -999;
long positionRight = -999;
newLeft = knobLeft.read();
newRight = knobRight.read();
if (newLeft != positionLeft || newRight != positionRight) {
Serial.print("Left = ");
Serial.print(newLeft);
Serial.print(", Right = ");
Serial.print(newRight);
positionLeft = newLeft;
positionRight = newRight;
// if a character is sent from the serial monitor,
// reset both back to zero.
if (Serial.available()) {
Serial.read();
Serial.println("Reset both knobs to zero");
knobLeft.write(0);
knobRight.write(0);
newLeft = newLeft/4;
newRight = newRight/4;
Post the code that does not work. I hooked up an encoder to my Uno and loaded your code with the change posted by @ blh64. In serial monitor, the count changes by 1.
/* Encoder Library - TwoKnobs Example
* http://www.pjrc.com/teensy/td_libs_Encoder.html
* This example code is in the public domain.
long newLeft, newRight;
Serial.read();
knobLeft.write(0);
knobRight.write(0);
newLeft = knobLeft.read()/4;
newRight = knobRight.read()/4;
