How to do a particular operation for 1 ms using arduino. How to set the timer
How to do a particular operation for 1 ms using arduino. How to set the timer values.
unsigned long then = micros();
while(millis() - then > 1000)
   // Do the one ms thing
Which timer? What values? What for?
PaulS:
That’d be 1,000ms - 1 second :stuck_out_tongue:
To do something for 1ms you need to do the same thing but with micros().
You’d think at first you could do:
unsigned long now = millis();
while (millis() == now) {
  // do something
but that would only do the “something” for the remainder of the current millisecond. If you start it half way through a millisecond you’ll only get half a millisecond’s worth of something.
So use a loop that executes until the number of microseconds exceeds 1000 more than the start time.
unsigned long now = micros();
while (micros() - now <= 1000) {
    // do something
startOperation();
delay(1);
stopOperation();
Psst, Paul- You mixed your millis() and micros() in your example...
PaulS:
What PaulS undoubtedly means is:
while(micros() - then <= 1000)
… as majenko pointed out.
