Hi all,
I am using Arduino Uno and Python' matplotlib to do real time plotting. It works on BMP280 sensor.
But now there is a problem, I am trying MQ7 sensor that needs delaying time to measure the CO.
Combining with MQ135 that does not need delaying time.
I just want to ask whether my .ino code or .py code is correct? Because when I run the python code, the pyplot GUI does not show up. What to do with sensor that has delaying time to measure data?
int R0 = 6692;
int R2 = 1000;
int sensorPin = A0;
int MQ7sensorValue = 0;
int sensorValue = 0;
float PPM_CO2;
float PPM_CO;
float RS;
float MQ7_CO;
// initialize the serial port
int sensorValue135 = analogRead(A2);
float volts = sensorValue135 * 5;
volts = volts / 1023;
RS = R2 * (1-volts);
RS = RS/volts;
PPM_CO2 = 470.627063 - 330.033*(RS/R0);
PPM_CO = 155.1505 - 129.2524*(RS/R0);
Serial.print(PPM_CO2);
Serial.print(",");
analogWrite(LED_BUILTIN, 255); // turn the heater fully on
delay(60000);
// now reduce the heating power
analogWrite(LED_BUILTIN, 72); // turn the heater to approx 1,4V
delay(90000);
digitalWrite(LED_BUILTIN, HIGH);
delay (50);
MQ7_CO = analogRead(sensorPin);
Serial.print(MQ7_CO);
The python code:
# https://toptechboy.com/python-with-arduino-lesson-11-plotting-and-graphing-live-data-from-arduino-with-matplotlib/
# https://python-forum.io/thread-32161.html
import serial # import Serial Library
import numpy # Import numpy
import matplotlib.pyplot as plt #import matplotlib library
from drawnow import *
PPM_CO2=[]
MQ7_CO= []
arduinoData = serial.Serial('/dev/ttyACM0', 115200) #Creating our serial object named arduinoData
plt.ion() #Tell matplotlib you want interactive mode to plot live data
cnt=0
def makeFig(): #Create a function that makes our desired plot
plt.ylim(23,25)
plt.title('MQ7 and MQ135 Live Streaming Sensor Data')
plt.grid(True)
plt.ylabel('CO2')
plt.plot(PPM_CO2, 'ro-', label='CO2 (from MQ135)')
plt.legend(loc='upper left')
plt2=plt.twinx()
plt.ylim(600,800)
plt2.plot(MQ7_CO, 'b^-', label='CO (from MQ7)')
plt2.set_ylabel('CO')
plt2.ticklabel_format(useOffset=False)
plt2.legend(loc='upper right')
while True: # While loop that loops forever
while (arduinoData.inWaiting()==0):
pass
arduinoString = arduinoData.readline().decode('ascii')
# print(arduinoString)
dataArray = arduinoString.split(',')
co2 = float(dataArray[0])
co = float(dataArray[1])
PPM_CO2.append(co2)
MQ7_CO.append(co)
drawnow(makeFig)
plt.pause(.000001)
cnt=cnt+1
if(cnt>50):
PPM_CO2.pop(0)
MQ7_CO.pop(0)
