How to do timer in 0.5sec HIGH and 9.5sec Low?
I can do timer like below
const long interval = 10000;
  if (currentMillis - previousMillis >= interval) {
    // save the last time you blinked the LED
Serial.println("renewal");
    // if the LED is off turn it on and vice-versa:
    if (ledState == LOW) {
      ledState = HIGH;
      ledState = LOW;
    // set the LED with the ledState of the variable:
    digitalWrite(ledPin, ledState);
it mean, it trigger LOW and HIGH for every 10sec.
but How can I manipulate to 0.5sec HIGH and rest of time LOW?
Partial code gives partial answer :wink:
But just use two intervals, one of 500ms and a second of 9500ms and use the correct one. Easy when you use an array.
When an interval ends you need to change the value in interval to the number required for the next interval. Something crudely like
    if (interval == 500) {
       interval = 9500;
    else {
      interval = 500;
   // etc
...R
Another way to skin this cat
const byte ledPin =  13;
unsigned long previousMillis = 0;
const byte states[] = {HIGH, LOW};
const unsigned long intervals[] = {9500, 500};
const byte NO_OF_INTERVALS = sizeof(intervals) / sizeof(intervals[0]);
byte state;
  pinMode(ledPin, OUTPUT);
  if (currentMillis - previousMillis >= intervals[state % NO_OF_INTERVALS])
    digitalWrite(ledPin, states[(state++) % 2]);
Another way to El Gato's pelt: :slight_smile:
// To set ON/OFF times, type in top of serial monitor:
// Example: 500 mS ON, 2000 mS OFF (lower case letters, no spaces)
// o500[ENTER], f2000[ENTER] or o500f2000[ENTER]
unsigned long iStart; // interval start
unsigned long onTime = 1000;
unsigned long offTime = 9000;
const byte ledPin = 13; // led pin
  Serial.begin(9600); //set serial monitor to match
  pinMode(ledPin,OUTPUT);
  prntIt();
  unsigned long iEnd = onTime + offTime;
  digitalWrite(ledPin,millis() - iStart < onTime);
  if(millis() - iStart > iEnd)
    iStart += iEnd;
  while (Serial.available() > 0)
    char inChar = Serial.read();
    if(inChar == 'o')
      onTime = Serial.parseInt();
    else if(inChar == 'f')
      offTime = Serial.parseInt();
       Serial.println("invalid input");
       while(Serial.available() > 0)
         Serial.read();
    iStart = millis();
    prntIt();
void prntIt()
  Serial.print("On Time = ");
  Serial.print(onTime);
  Serial.print("  Off Time = ");
  Serial.print(offTime);
  Serial.println("\n");
You can use milis() or a timer.
For an example of timer using a library (you can look inside and take your needed code), using GitHub - Naguissa/uTimerLib: Arduino tiny and cross-device compatible timer library
#include "uTimerLib.h"
unsigned char ledControl = 0;
// LED is LED pin global variable
void blinkLed() {
	digitalWrite(LED, ledControl == 0 ? HIGHT : LOW); // You can decide when to blink the led in the period
	ledControl = (ledControl + 1) % 20; // 0,5sec hight, 9,5sec low is 1/20th
	// [..whatever, as set led pin as output]
	TimerLib.setInterval_us(blinkLed, 500000); // 500,000 microseconds, as 20 times in 10 seconds
// Rest of your program
