I would like to know how to draw qrcode on Waveshare 1.54inch e-paper display. I've used that library: GitHub - ricmoo/QRCode: QR code generation library in C, optimized for low-power devices, such as Arduino., the example only shows printing on Serial.
Hi maksumon,
You just need to draw filled rectangles in black or white to the display. Try to do it on a TFT first, if you have one. If you use a TFT library with standard Adafruit_GFX fillRect() method, it should be easy to use it then with an e-paper library, e.g. GxEPD.
I would first search for qrcode in the Arduino Forum, I did, but did not see a directly usable entry for TFTs, but maybe this for LCD has some useful info: Encoding and generating QR Codes
